Problems with rear SPC camber
Old Mar 21, 2009 | 05:27 PM
Eug96's Avatar
Hey,
Very disappointing day today. Went to have the rear camber installed but couldn’t have it go into spec. Whenever they would adjust the camber the toe would be off. If they adjusted the toe back into spec, it would throw the camber off. I forgot to ask them for a print-off to post on here but they said they adjusted the camber from -2.40 to about -1.30
Can anyone inquire?
Old Mar 21, 2009 | 06:49 PM
johnnyzee's Avatar
Old Mar 21, 2009 | 06:50 PM
simpson's Avatar
get a new shop they sound stupid
Old Mar 21, 2009 | 06:59 PM
Eug96's Avatar
I watched them try to adjust it, the camber would be off when they adjusted the toe, then the toe would go off when they tried to adjust the camber
Old Mar 21, 2009 | 07:17 PM
simpson's Avatar
sounds weird when they got the camber did they tighten it down then do the toe?
Old Mar 21, 2009 | 08:06 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
+1
Sure they all interact while being aligned.
But for a GOOD tech this should be no problem.
Old Mar 21, 2009 | 08:15 PM
bertmauricio's Avatar
Did they install toe bolt kit along with the arms? I needed the bolts to get toe into spec.
Old Mar 21, 2009 | 08:29 PM
mishmosh's Avatar
sounds like they did NOT install the toe kit correctly. It is not just about putting the toe bolt in, they have to grind down the capsule shaped hole for extra movement on the inside. If they didn't do this, there is no added toe correction over stock!!! Eibach is a conservative drop, they should easily be able to correct camber and toe if you had the camber/toe kit installed.
Also, as above, the shop could be bad. Some shops are just used to correcting toe and don't even bother with camber. go to the dealer if you have to.
Here's mine from last week (with SPC front camber kit as well):
Old Mar 21, 2009 | 08:54 PM
jran76's Avatar
I did not need the rear toe kit. I can tell you, when you adjust camber, it does affect the toe. My toe was WAY off when I installed the SPC camber arms, and I adjusted the camber arms (not the toe) to get the toe in so I could at least drive the car. This obviously changed the camber too, but it got my toe close to spec.
I agree that you need to go to another shop.
Old Mar 21, 2009 | 11:31 PM
Wes_888's Avatar
Where did you get this done?
Old Mar 21, 2009 | 11:55 PM
mishmosh's Avatar
Some people have reported that they were able to zero the toe without the toe bolts and some reported they needed the toe bolt. Because the install is so easy, I would recommend that people just go ahead and install them--heck they come with the SPC camber arms anyways, so why not?
Here is the toe kit DIY for anyone interested. The dremel cutting bit mentioned cuts the metal like butter!
http://my350z.com/forum/brakes-and-s...-protocav.html
Old Mar 22, 2009 | 08:32 AM
simpson's Avatar
i never even put my toe bolts in
Old Mar 23, 2009 | 08:24 AM
Cabad85's Avatar
+1 on going to a different/better shop. the guy(a 2-3 person local performance shop) who did my alignment was able to get my toe, in spec after the eibach drop. he had to setup for an extra deg of neg camber in order to achieve this though. i have the toe-bolts but i did not install them. he said that the -1 deg of camber will accelerate the wear of the rear tires, but not by much. i would just keep an eye on tire wear and get them installed if needed. it's toe-in/out that eat up tires the most. hope this helps
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
