*Safety Alert* Is everyone using OEM Shank style lugnuts on their wheels?
Feb 9, 2010 | 08:05 PM
  #31
^my 08 sport wheels take the same shank style as the coupe 19s
Reply 1
Feb 9, 2010 | 10:27 PM
  #32
Quote: Anyone? 35K on the car and counting....gonna swing by Infiniti or Nissan on the way home from work.
I ordered them from calwheelaccessories.com. $1.75 per lug nut for the newer kind, $1.32 each for the other.
Newer shank style lugs
http://www.calwheelaccessories.com/f...e-mag-lug-nuts
Acorn style lugs
http://www.calwheelaccessories.com/f...acorn-lug-nuts
Reply 0
Feb 10, 2010 | 01:33 PM
  #33
Quote: I ordered them from calwheelaccessories.com. $1.75 per lug nut for the newer kind, $1.32 each for the other.
Acorn style lugs
Kvangil thanks for the info bro I appreciate you linking the info for me.
My only question is I have a 07 G35 Journey (if that matters) I had the stock 17" wheels and I bought the 19" M Sport wheels. I am currently using the lug nuts from my old rims on my M wheels. Which lug nuts should I go with option A Shank Style or option B Acorn style. Is Acorn and concial the same thing?
Thanks for the help guys.
Reply 0
Feb 10, 2010 | 01:51 PM
  #34
^ you should definitely use the shank style for the coupe 19s
Reply 0
Feb 10, 2010 | 02:16 PM
  #35
Intgr8r - thanks for the info. but I have the M Sport wheels from the M45 Sedan not coupe.
Reply 0
Feb 10, 2010 | 03:29 PM
  #36
Quote: Intgr8r - thanks for the info. but I have the M Sport wheels from the M45 Sedan not coupe.
Sorry, I don't recall what seats the M45 wheels have.
You can give Wes_888 a PM, he ran M wheels on his sedan.
Also,
You can tell by looking at the lug nut seat of the wheel.
If shank style, the wheel seat has that same profile.
Reply 0
Mar 14, 2010 | 08:10 PM
  #37
So.... I been using regular lugnuts for 17k... ...
can I buy either one?
Acorn style lugs
Also, do I have to get new wheel lock? If i do, which one you guys recommend?
Thanks!
Reply 0
Mar 15, 2010 | 07:44 PM
  #38
If I am not mistaken you want to buy the Acorn style (older) not the Shank style (newer which is already on your car).
Reply 0
Mar 17, 2010 | 12:42 AM
  #39
so... I should buy 16x of Acorn style lugs and a acorn wheel lock?
Thanks!
Reply 0
Mar 24, 2010 | 01:22 PM
  #40
Yes I believe so.
Reply 0
Jul 9, 2010 | 03:43 AM
  #41
Can I use OEM Infiniti wheel locks (one for each wheel) with the aftermarket wheels (OZ Ultraleggera), which use conical type lugnuts?
Reply 0
Jul 30, 2010 | 08:36 AM
  #42
hello?
Reply 0
Jul 30, 2010 | 09:16 AM
  #43
Quote: Can I use OEM Infiniti wheel locks (one for each wheel) with the aftermarket wheels (OZ Ultraleggera), which use conical type lugnuts?
You have the 2nd Gen OEM lock nuts, don't you? The ones with the washer will not work properly with wheels that require cone type nuts.
Get tuner lock nuts for your OZ's.
Reply 0
Nov 1, 2010 | 10:16 AM
  #44
I'm glad I was pointed to this thread. I didn't realize there was a difference until I tried to mount aftermarket rims used on a 2006 g35 (with winter tires) on my 08 G35x and the lug nuts wouldn't physically pass through the opening since the washer section of the newer lug nut was wider than the hole on the 06 rim. I went to my local Nissan dealer and picked up the older Acorn conical style and will try them out this week.
Reply 0
Feb 25, 2011 | 05:13 PM
  #45
So I'm still confused. Can I use these on an 07 G35 Sedan Journey with stock rims?
the bigger one not the smaller gorilla ones
The are DGR Suspension ones
Reply 0
