Difference between suspension on G37 Coupe and 07+ G Sedan
Old Apr 22, 2009 | 04:56 PM
paulg35s's Avatar
The 2nd Gen G Coupes & Sedans seem to have a lot of similarities as far as the suspension goes. I know this because all the Strut Bars and the Under-Braces are direct fits on both cars. The question is, will Coilovers for the G37 Coupe fit our Sedans? I know that our Sedans are a bit lighter, so the spring rate may need to be adjusted, but will everything bolt right up? Any insight will be helpful.
Old Apr 22, 2009 | 05:45 PM
E-Ticket Ride's Avatar
Yes. The coupe spring rates are usually higher than those for the sedans, so beware of that.
Old Apr 22, 2009 | 06:10 PM
paulg35s's Avatar
So do you think everything will be good except for the spring rates? I can easily order a set of the coils with specific rates.
Old Apr 22, 2009 | 06:27 PM
yep
Old Apr 22, 2009 | 06:41 PM
Gsedan35's Avatar
Past practice
Oem spring rates
2003-2005 350Z
314/342
2003-2006 G35 sedan with sport suspension
314/342
2003-2007 G35 coupe when delivered on oem 17 or 18 inch wheels
314/342
2004.5-2008 350Z (revised suspension)
314/427
2005-2007 G35 coupe when delivered on oem 19" wheels
314/427
If you want to bed the issue, send me a single front and rear oem spring, I'll get the spring rates and return the springs FedEx ground on my dime. 3 different owners have done just that in the last 3 years to get rates we'd otherwise still be wondering about.
Old Apr 22, 2009 | 07:33 PM
That's interesting, as I've never seen anyone who actually knew the exact rates. Even reputable guys like Lou can only guestimate the rates when asked.
I was referring to the rates on CO's though, but who knows, they're probably close if not the same. Most of the CO's I've seen have a little stiffer rate for the coupes versus the sedan (now I wonder why after seeing the rates you posted).
Old May 22, 2011 | 12:15 PM
Byteman's Avatar
Hi guys,
does anyone know what the OEM spring rates are on a base (RWD) 2007 G35 Sedan non-sport?
Thanks.
Old May 22, 2011 | 01:15 PM
6mtg37s's Avatar
I have g37 coupe eibachs on my sedan, works and looks great!
Old May 22, 2011 | 01:16 PM
6mtg37s's Avatar
Oh an weight difference is about 50-100 pounds so any spring rate for the coupe will also work for the sedan
Old May 23, 2011 | 02:02 AM
Byteman's Avatar
Thanks for replying 6mtg37s.
It still doesn't answer my question .. I've seen here on different threads
that the OEM G35 Sedan non-sport rates are F:283 R:308
but it looks like those refer to the 2006 and before; it doesn't clearly
say it whether they apply to the 2007 as well .. therefore my question.
Thx.
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
newg37
Jul 26, 2015 09:32 AM
itschuckster
Jul 25, 2015 08:07 AM
