stock rear camber adjustment G35X
Old Apr 24, 2009 | 01:53 AM
new35's Avatar
I have had my G aligned evry fall and spring when I change over my tires from BLizzaks to Goodyears. When I get the printout of the alignment
all wheels are in spec except for the right rear wheel - 1.4.... the alignment machine is a HUnter 2009 with lasers..... they tellme the rear camber is fixed ?I went to the dealer and they said it was adjustable?
any of you rear suspension experts noif its a fixed setting or can it be adjusted.... the HUnter alignment book says its needs shims or an after market kit..... your thughts would be appreciated
RichB
Old Apr 24, 2009 | 08:52 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Yes the rear is adjustable.
It's a bolt with a cam type of adjuster.
If the Hunter is calling for shims etc, they have the wrong car in the data base OR
they are confused between front and rear.
(front has no adj.)
Old Apr 24, 2009 | 09:46 AM
terrycs's Avatar
Are they trying to tell you that they ran out of adjustment? This would make sense.
Old Apr 24, 2009 | 02:21 PM
CalsonicVQ's Avatar
+1. Your rear camber is adjustable (to a limited degree). If you're at stock height, there's no reason why your alignment can't be brought back into spec (unless something is broken/bent). If I were you, I'd go back to the alignment shop, point out the rear camber bolts and get the car realigned. Else, demand your money back.
jimNC
Jul 25, 2015 05:47 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
nascarbuff17
Jul 16, 2015 10:23 AM
