Decision time for Springs!
I am getting the idea that I will be waiting a long time for coilovers or AWD specific springs to be available for the G37x sedan. Therefore, I have decided to go with one of the following two choices:
1 - Eibach G37 Sedan Part # 6390.140
2 - Eibach G37x Coupe Part # 6394.140
I am open to opinions on which set would be better suited for me. The G37x coupe springs lower that car by 1.9F and 1.6R. The G37 sedan springs lower that car by 1.5F and 1.2R. I have no idea how these numbers would translate for my G37x sedan. Any insights?
I am thinking that I would prefer the larger drop as the G37x has a huge SUV type wheel gap to deal with.
Any suggestions are welcomed
Depending on where you live, I am assuming somewhere in the snowbelt due to you buying an X, I would go for a slightly more conservative drop ie the Eibach springs for the G37 sedan. You never know when that extra 0.4 inches will come into play and help you clear snow.
I also think that the spring rates are different so maybe putting the coupe springs on maybe a liability issue? Perhaps you can try asking this question on myG37 and see what responses you might get.
How much wheel gap do you have left? Also, do the sedan springs lower the AWD model the same amount as they lower the non-AWD model?
Ya Scott that first pic is like "wow" but i def. like your wheels,, sort of masks the prob. slightly,,, I just installed mine last week,, took some pics,, but didn't like the angles, and car was dirty,,, Be advised,, i need rear camber arms for mine,, i am - 2* allthough the car corners fabulously!!!
