Installed the Akebono brakes - finally
#62
#64
Those offsets are pretty close to what I'll be running except I'll have a 9" wide wheel up front and 10-1/2" in the rear. Can you tell me how much clearance you have between the inside edge of the rear wheel and the toe link that runs from the rear hub towards the front of the car? I'm hoping to be able to run a 48 mm offset with the 10-1/2" wide rear wheels, but am a little worried about the inside clearance.
#66
......... Can you tell me how much clearance you have between the inside edge of the rear wheel and the toe link that runs from the rear hub towards the front of the car? I'm hoping to be able to run a 48 mm offset with the 10-1/2" wide rear wheels, but am a little worried about the inside clearance.
911Turbo
19 Inch
08-24-2016 08:31 AM
