Question about jack points
Old Nov 30, 2009 | 08:52 AM
johnnyzee's Avatar
Curious what you guys think...
Is it OK to lift the whole rear of the car by jacking the rear differential (I use rubber pad jack cup so no metal on metal damage would apply)?
If not, where do you guys jack from (aside from the frame rails)?
Old Nov 30, 2009 | 10:42 AM
E-Ticket Ride's Avatar
The rear diff is the recommended jack point.
Old Nov 30, 2009 | 12:37 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
If I'm lifting to put on stands, that's what I do ^
The front also has a point in the middle.
If I'm just jacking to swap wheels;
I jack from the Front/side lift point.
I can do both f&r wheels in one lift.
Old Dec 1, 2009 | 11:33 AM
johnnyzee's Avatar
Thanks guys,
Ian, I do the same thing for the wheels, I lift the whole side of the car by the frame rail and hit both wheels at once.
I just needed to know if the rear diff was safe for lift, I did so when I swapped my rear springs, but still wasn't sure if that was OK.
again, thanks!
Old Dec 3, 2009 | 12:00 AM
Rottten Appples's Avatar
Originally Posted by e-ticket ride
the rear diff is the recommended jack point.
+1 e-ticket
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
gatorglaze
Intake & Exhaust
Aug 17, 2015 02:16 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
DRG35R
Jul 31, 2015 10:23 AM
