Alignment issue
Old Nov 30, 2009 | 04:46 PM
soundmike's Avatar
Alignment issue
Guys, i'd appreciate some input here.
Brought the car in for a 4 wheel alignment, for the most part everything is within spec except for the front right camber which is off by just a hair from the recommended range. L-R difference is roughly 0.4 degrees.
Toe couldn't be zeroed out on any corner, but it's very close to 0 (IIRC, 0.03 on average).
I am still on stock suspension. Does this sound right? Judging from what's happening with the front, would this mean if i dropped the car a front camber kit would then be necessary at this point?
Or, do i need to find another alignment shop?
p.s. My steering wheel is also tilted slightly to the left now, it does track straight though.
p.p.s. Handling feels really loose now. I think i'm going to ask for some camber to be dialed back in.
Thanks!
Old Nov 30, 2009 | 08:07 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
do you have your before & after numbers?
Old Nov 30, 2009 | 08:14 PM
soundmike's Avatar
Unfortunately, i only have the afters. Had to write that down, too. Their printer wasn't working <g>
rezendvous420
May 31, 2020 01:26 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
itschuckster
Jul 25, 2015 08:07 AM
beevanhuynh
Jul 23, 2015 01:37 AM
