When you drop your car do you readjust headlights?
Old Jan 7, 2010 | 01:43 PM
remo's Avatar
So if I drop my car on Eibachs, do I have to readjust my headlights. Common sense said I should because car is lower so angle of headlights changes with it. Does it make sense?
Old Jan 7, 2010 | 03:25 PM
g-adabout's Avatar
I lowered mine on Eibachs and i didnt notice a difference on the angle or area lit up by my headlights.
If I compared mine before and after I might have noticed.
If you do decided to lower it, take pics or measure the beam height to answer this. I would like to see the results.
Old Jan 7, 2010 | 03:27 PM
BocaIvan's Avatar
I didn't adjust mine...
Old Jan 7, 2010 | 03:33 PM
J2S2M's Avatar
I lowered my G on H&R's and noticed a significant change where the cutoff of the lights are.. still I was too lazy to adjust it. I eventually got used to the change.
I recommend adjusting the cutoff if it bugs you. IMO w/ Eibach drop, you don't really need to adjust it. If you go lower, then I recommend them to be adjusted accordingly.
GL
Old Jan 7, 2010 | 03:42 PM
terrycs's Avatar
Depends on whether or not one has auto leveling headlights.
The auto leveling headlights are controlled by a sensor on the rear suspension. Lowering the car will make the headlight leveling system think you have a heavy load in the trunk and drive the headlights down.
There is an adjustment in the CONSULT-III to zero the system after you lower the car. I have not had mine done yet so I don't know how much difference it would make.
Alternatively, you can physically aim the headlights old school style with the adjustment screws on the housing assemblies.
Old Jan 7, 2010 | 04:25 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
I don't have auto level.
I haven't done mine but I need to.
Depending on how it's lowered, the rake also changes, which will have a bigger impact than drop alone.
Old Jan 8, 2010 | 04:16 PM
boss81's Avatar
Old Jan 11, 2010 | 04:03 PM
kmuniz78's Avatar
...auto leveling huh. Must be on the cars that have adaptive headlights. Didn't think our cars had this feature... Hmmm, time to consult my owner's manual.
Sepsis
Feb 12, 2020 02:05 PM
bTanz
Oct 15, 2015 02:31 PM
Karnicle
Jul 23, 2015 05:08 AM
Soumilg
Jul 18, 2015 12:33 PM
attarday
Jul 15, 2015 04:03 PM
