nail on side of tire..what to do?
Old Jan 10, 2010 | 11:07 PM
g35xerman's Avatar
I have a nail on my rear passenger tire. The nail is very close to the sidewall which the tire shop has told me it cannot be repaired and they do not carry Goodyear eagel rsa 225/55/17. They have advised me to go to another shop replace the one tire.
My question is I have a G35X with close to 30000 KM on it. Can i replace just the one tire? Will a new tire throw off the AWD system as it will have a larger diameter?
Old Jan 10, 2010 | 11:29 PM
LakeShore_Slate's Avatar
PIC? you may want to replace the other driver side rear tire as well. why would you get a tire with a larger diameter?
Old Jan 10, 2010 | 11:33 PM
thescreensavers's Avatar
Mr.202?
At least it was a Eagle RSA, such crappy tires.
Now you can get better tires :S
Old Jan 10, 2010 | 11:47 PM
g35xerman's Avatar
well the tire tread on the new tire will have more tread even if i get the same size. so the diameter is going to be more. won't it?
sorry have not had a chance to take pic...
Old Jan 10, 2010 | 11:50 PM
Dubi2087's Avatar
You can get one new tire AS long as the other old tires have 6/32nd or more of tread on them.
Old Jan 11, 2010 | 01:13 AM
Gdrift's Avatar
I had a tire go bad and I decided to change both because it just felt weird with one. I say get one, if you don't like the feel of it, order another one.
Old Jan 11, 2010 | 01:29 AM
JOKER's Avatar
CLUB MODERATOR
it's all depends on how much longer your other tires gonna last.
If it's another 5K then replace all of them
if it's 20k then you might wanna look into flat repair kit or used tire.
Old Jan 11, 2010 | 08:49 AM
blnewt's Avatar
Just get 4 real tires
Old Jan 11, 2010 | 09:03 AM
kregg's Avatar
This is what I would do, unless you don't like the tire like others mentioned, replace the set or all four. I am trying to find a reason to replace my stockers, I'm not a fan of 'em, but dropping the $500+ doesn't give me a thrill either.
Old Jan 11, 2010 | 09:50 AM
gooddeal2's Avatar
30k KM = ~19k miles is a lot already. I think you need to replace at least 2 but you might just change all 4. If you're near Costco's or Sam's, you can a good deal there when you buy 4 tires.
Old Jan 11, 2010 | 10:02 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
If it's near or on the sidewall, than replace do not repair.
The sidewall goes through lost of stress & flexing, it's not worth the safety risk, IMO.
Old Jan 11, 2010 | 10:03 AM
cruzdog's Avatar
If you do stick with Goodyear or with Gemini Service (they carry Dunlops and Michelins as well) go for the $14 per tire road hazard.
Had the same issue as you - nail on the edge - replaced the tire and within a month - GOT ANOTHER NAIL! New tire for free...
Old Jan 11, 2010 | 07:26 PM
RBull's Avatar
Rated M
+1
The difference in diameter is minor. Change 1 unless you're close to changing them all.
wonderizm
Sep 24, 2015 03:09 AM
Jiggerjuice
Aug 31, 2015 11:49 AM
paolojericho11
Aug 27, 2015 10:21 PM
Tylerttn
Aug 10, 2015 07:13 AM
