Will these Volk wheels fit?
Old Feb 4, 2010 | 10:15 AM
Thug n Black S's Avatar
hey guys,
i know its a newb question but im thinking about buying some used GT30s from another user here and wanted to verify they would fit my 08 35s. I'm about to put eibach pro-kit springs and drop it too.
The wheels are:
20" GT30
20 x 8.5 +43 (245/35/20)
20 x 9.5 +37 (275/30/20)
will the fenders have to be rolled and why is the back offset higher than the front, i thought it was supposed to be the other way around.
any help is greatly appreciated
Old Feb 6, 2010 | 03:38 PM
Q8y_drifter's Avatar
they should fit perfectly but the fronts may need spacers for better stance.
Old Feb 6, 2010 | 03:39 PM
LordFappington's Avatar
the lower the number the lower the offset. +37 is less than +43
Old Feb 6, 2010 | 03:51 PM
A 10" wheel with a +37 offset sohluld have a bigger lip than a 10" wheel with a +43 offset. Assuming they are the same wheel design.
Old Feb 8, 2010 | 01:24 PM
jimmyjones's Avatar
definitely going to need spacers on the front but the rears should be close, it all depends on how aggressive you want it to look.
to answer your questions: Yes they will fit, No you will not need to roll the fenders. lower offset = bigger lip (37 offset has 6mm more lip than 43mm offset)
Old Feb 8, 2010 | 03:28 PM
jran76's Avatar
I would do a 15mm spacer up front. I am running a 8.5" +36 and 9.5" +37, and I could use a 10-15mm spacer on my fronts, so you definitely will need to do something if you want them even/flush. I also have Eibach pro-kit springs (rear is about -1.6 degrees camber with a camber kit, and front is about -1.8 with no camber kit).
Pic:
Few more pics here: https://g35driver.com/forums/media-s...g-begin-2.html
Old Feb 10, 2010 | 11:25 AM
kmuniz78's Avatar
[Quick thread jack]
jran76 - How did I miss your pics of the GT-S'... I actually got mine back on 5/29/08 after ordering them 109 days prior. Nice choice!
https://g35driver.com/forums/nationa...ml#post3065004
Old Feb 10, 2010 | 11:48 AM
sunny G-35 NYC's Avatar
They would fit perfect with the drop
bu villain
19 Inch
Nov 15, 2015 09:23 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
neight
Aug 3, 2015 11:27 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
