WTF are these??
Old Feb 10, 2010 | 11:28 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by Inyong1988
Main reason would be preventing from mount wrong rotors, but secure and holds up rotors are another part of the reason. Therefore, You are wrong.
I also clearly stated that you can go ahead and remove the bolts when you install an aftermarket set of wheels. (which what op needed to know)
No... the hole is tapped in the rotor itself, not the hub behind it.
There is no bolt hole in the hub.
The bolt has nothing to do with the rotor.
It's only a wheel rejection bolt.
But yes you are correct, it can be safely removed.
Old Feb 10, 2010 | 11:30 AM
JBF's Avatar
JBF
actually you are wrong about securing the rotor. the bolt screws in to the rotor and thats it.
you could say the caliper and brake pads secure it. and MAYBE even the wheel and lug nuts...lol
But that bolt was installed to only prevent the rear wheels being installed
Old Feb 10, 2010 | 12:41 PM
soundmike's Avatar
I think all Nissan rotors have those holes (the G being the only one i've seen with the bolt). Would be nice if they had similar holes for the rears. It would make rotor replacement so much easier!
Old Feb 10, 2010 | 06:13 PM
Defratos's Avatar
You're Despicable
Originally Posted by kregg
being on a sand dune prolly helps the hat from rusting on the hub face. 1 yr in well salted central NY winters makes this bolt needed for rotor removal. Consider yourself and your undercarriage lucky
wow and I thought mine we're pretty rusted as it is. I live right by the sea as well so we get a lot of salt from there. the bottom of the car is rusted pretty bad, but I guess you guys have it worse. Especially with all the snow now
Old Feb 10, 2010 | 06:22 PM
Defratos's Avatar
You're Despicable
and guys stop fighting
baker2795
Sep 2, 2015 06:00 PM
justICE
West
May 9, 2004 11:51 PM
sux2bu
May 5, 2004 08:37 PM
