WTF are these??
Old Feb 9, 2010 | 12:56 PM
Defratos's Avatar
You're Despicable
Angry WTF are these??
So I tried installing some new rims today, and guess what they don't fit. This stupid bolt below seems to be hitting the inside of the new wheel
two questions:
1) What is it?
2) Can I remove it somehow?
This is how the inside of the new rims looks, they're 19x9 offset 25
and I've got the adaptors to fit the new rims, but the bolt above hits before they even touch the adapters
Old Feb 9, 2010 | 12:58 PM
Inyong1988's Avatar
It's just a little bolt to secure your rotors. ( only two on the front two rotors) you can remove them when you install an aftermarket set of wheels. It's no biggie. Wheels are strong enough to push and secure them on place.
It's that simple.
Calvin's Avatar
Overglorified Altima
Take those bolts off. They're just there so you don't accidentally put the OEM rears on the fronts.
Old Feb 9, 2010 | 12:59 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
REjection bolts, so that rear wheels don't get mounted up front.
...just remove them
:edit:
wow, you have to be quick around here
Old Feb 9, 2010 | 01:14 PM
Defratos's Avatar
You're Despicable
Damn man, Bloody hell and I just got back from the little workshop we have Damn damn damn it,,
Now Dilemma, do I leave it for tomorrow? or do I go finish it off today?.....humm I think I'll leave it for tomorrow.
Thanks for the quick response guys, it's really helped me out I was $hitting it for a sec
Old Feb 10, 2010 | 02:49 AM
G35xQX1's Avatar
please make sure to post pics of your ten spoked goodness mounted on your G
Old Feb 10, 2010 | 03:12 AM
Defratos's Avatar
You're Despicable
lol will do so, either today or tomorrow
Old Feb 10, 2010 | 03:40 AM
AboostedG's Avatar
two questions:
1) What is it?
Now that you have your answer... Make a thread & Post Pics...
Old Feb 10, 2010 | 03:48 AM
Defratos's Avatar
You're Despicable
lol well hey I'm new to *** cars anyway, so those silly bolts were a first for me
Will have pics up once they're installed but I doubt I'll have time today as I've got a wedding to go to later on.
So looks like Thursday is the day
Old Feb 10, 2010 | 03:52 AM
B L U E S L A T E's Avatar
Honda Accord
Can't wait to see them!
Old Feb 10, 2010 | 04:39 AM
jutn35's Avatar
G35 Coupe
It's that simple.
WRONG!!!
its just a bolt that prevents you from installing the wrong size rims on your front since your front and rear rims are different size.
It has nothing to do with the rotor
Old Feb 10, 2010 | 09:26 AM
soundmike's Avatar
And a tip... once that bolt is off, if you can find a longer version of it you can use that longer bolt to take the front rotors off should the need arise ... a minute, tops, and no banging
Old Feb 10, 2010 | 09:35 AM
Defratos's Avatar
You're Despicable
Do you mean screwing a longer one and pulling the rotors out that way?
Yesterday when I playing around the rotors already seemed pretty loose to start off with.
Old Feb 10, 2010 | 11:08 AM
kregg's Avatar
being on a sand dune prolly helps the hat from rusting on the hub face. 1 yr in well salted central NY winters makes this bolt needed for rotor removal. Consider yourself and your undercarriage lucky
Old Feb 10, 2010 | 11:21 AM
Inyong1988's Avatar
Originally Posted by jutn35
WRONG!!!
Main reason would be preventing from mount wrong rotors, but secure and holds up rotors are another part of the reason. Therefore, You are wrong.
I also clearly stated that you can go ahead and remove the bolts when you install an aftermarket set of wheels. (which what op needed to know)
