camber kits - DIY install or not?
Old 08-16-2010, 08:04 PM
mishmosh's Avatar
Agreed. Pretty straightforward, especially if you've done springs/shocks before. I also tried correcting both front and rear camber--ended up perfect. I figure most shops just like to zero the toe anyways and I didn't want them to touch the camber kit pieces anyways.
Old 08-16-2010, 08:20 PM
nsp106's Avatar
The question I was trying to get at was, If i buy a camber kit (Front & Rear), do I need to buy an adjustable toe kit too?
Old 08-16-2010, 08:25 PM
salvador312's Avatar
So, If i drop my car. I need camber kits no matter what?
Old 08-16-2010, 08:58 PM
nsp106's Avatar
No, but to avoid excessive wear on the inside of your tires, yes.
Old 08-18-2010, 12:45 AM
JZ's Avatar
JZ
JZ is offline
G35 Coupe KY0
josh... whats your price for these rear camber adjusters?
Old 08-19-2010, 12:11 AM
terrycs's Avatar
Depends on the kit.
The toe bolts are for the rear. The Eibach / SPC kit for the rear includes BOTH camber arms and toe bolts.
Old 08-19-2010, 10:00 AM
BlueFlash's Avatar
i'm running 1.8 up front and 2.1 in the rear, 6k miles so far and the tires look fine...although i never expect to juice 20k out of my tires anyway....as long as I get 12k i'm fine...
Z1Motorsports
Suspension-Vendor
56
05-31-2020 01:56 PM
Tolboothwilley™
Exterior-Vendor
07-28-2016 12:42 AM
paolojericho11
09-11-2015 07:08 AM
socalg35x
08-07-2015 09:36 AM
nascarbuff17
07-16-2015 10:23 AM
Quick Reply: camber kits - DIY install or not?
