Ichiba spacers on 2nd Gen, what lugs do i need?
Do you guys know if the current Ichiba spacers come with the longer shank-style lugnuts (which is needed for 2nd gen) or do they use the conical setup?
Thanx
Thanx
so i can reuse the original lugs on the 10mm spacers then?
it should still be the same in regards to mounting the spacers/rims combo.
with the 335i my 10mm spacers came with longer lug bolts, which replaced the OEM and my summer (BBS) wheels
Yup bolts vs studs.
But it's not just a Japaneses thing; most mfgs use wheel studs.
I never did like wheel bolts on my BMW.
It's much easier changing wheels with studs.
A lot of BMW guys that track their car, install studs.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
FreshVQ
Sep 30, 2015 01:41 PM
