GT Spec braces
Old Mar 11, 2010 | 08:53 PM
  #31
mishmosh's Avatar
The other weird thing is that you burnt out your dremel. If you use it right, you let the speed and bit do the work...try not to put too much strain on the dremel. I actually bought 2 bits because I heard that some used more than one, but one was all I needed--the bit still looked like new after. I think that metal is just aluminum alloy. I used the flex extension with mine.
Old Mar 15, 2010 | 01:11 PM
  #32
bsowhat1's Avatar
On the 1st gen G the rear subframe was aluminum. Dremel is able to elongate the holes easily. The 2nd gen cars have a steel subframe which will take a lot more work to grind/Dremel.
Old Mar 15, 2010 | 03:07 PM
  #33
Defratos's Avatar
You're Despicable
well can it be done with a dremel? and Mishmosh yours is a 1st gen?
Old Mar 15, 2010 | 03:10 PM
  #34
E-Ticket Ride's Avatar
He has a 2nd gen Maz.
Old Mar 15, 2010 | 03:15 PM
  #35
Defratos's Avatar
You're Despicable
lol ok I'm not clear on when the cut off period for 1st and 2nd gen are
But how come he had such an easy time elongating his hole and I fried my dremel after an hour on one hole?
Do dremels come in different power ratings or something? could it be that I just had a weak dremel?
and here's something to cheer you guys up: -------> https://g35driver.com/forums/lounge-...secretary.html
Old Mar 15, 2010 | 03:37 PM
  #36
mishmosh's Avatar
OK, my mistake about the steel...I guess that's why it's painted black. Still, I had no trouble with a dremel, the flex extension, and one carbide bit. Just take your time.
Old Mar 15, 2010 | 03:48 PM
  #37
Defratos's Avatar
You're Despicable
I took a whole damn hour on one hole I think that's taking your time
Can you tell me which dremel you have and the model? I want to check up on the power rating and see if mine was crap....oh yeah I also have to check if I was using the right wattage.
Old Mar 15, 2010 | 04:17 PM
  #38
mishmosh's Avatar
My dremel says 300-1/40T. The flex shaft fits a lot of models. I swear, it only took 5 minutes a hole! I put it on a fast speed if that make any difference and made sure not to let it bog down.
Old Mar 15, 2010 | 04:33 PM
  #39
Defratos's Avatar
You're Despicable
lol no you're not helping now I just feel miserable that I couldn't do mine
lol j/k thanks for the info
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
