Lowered 08 G35's and Daily Driving
Old Mar 31, 2010 | 05:04 PM
drupy12g's Avatar
I have looked thru the threads and not really found anything on this, but how is the daily driving on G35's lowered with either springs or coilovers? I drive quite a bit on a daily basis (50+ r/t) mostly freeway, so this is a major concern with me before I spend the money to drop the car. Any thoughts would be greatly appreciated!
Old Mar 31, 2010 | 08:40 PM
sunny G-35 NYC's Avatar
My G is lowered and I do daily driving about 40 miles, and I have been driving for almost 10,000 miles on the springs and I have no problems of any kind. You get better handling when you go lower.
Old Apr 1, 2010 | 08:29 PM
texasmax's Avatar
Lowered with Eibach pro-kit springs (and the 19s from the coupe), 26 mile commute each way, no driveability issues at all. A few thousand miles on it so far.
Old Apr 1, 2010 | 08:58 PM
J2S2M's Avatar
Drop it like itz hot! If you don't like it.. which I highly doubt, you can always put your stock springs back on.
Old Apr 1, 2010 | 09:19 PM
velomack's Avatar
Eibach Pro Kit also, 20 inch rims. No drivability problems. Stiffer ride though and it will not be as comfortable as stock, but not that noticeable. Keep in the back of you mind camber adjustment kit (front) and toe bolts (rear). This will save you some tires in the long run.
vmcarbuyer
Oct 12, 2019 12:42 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
wojowojo16
Jul 27, 2015 09:57 AM
laksjd84
Jul 24, 2015 05:12 PM
Karnicle
Jul 23, 2015 05:08 AM
