Urgent input/advice needed on e-brake-vdc-slip-cruise lights coming on!
Old Apr 19, 2010 | 05:26 PM
djfarhan's Avatar
Question Urgent input/advice needed on e-brake-vdc-slip-cruise lights coming on!
Whats goin on guys,
I have a 07 g35x (came with 13k on it last july, has 22k right now). So i was driving this past weekend and while i am on the highway, as i am driving, the e-brake parking light comes on all of a sudden, and then the VDC and SLIP light comes on, and since i had my cruise control on, the CRUISE light came on as well. Car was fine, didnt feel anything wrong, but those lights stayed on. I pulled over, turned off my car and turned it back on, they were all gone. Then a few minutes after i got back on the highway, it did it again. I took a picture of it. Here it is.
Called the dealership today and told them about it, they say that THAT MEANS MY BRAKES NEED TO BE REPLACED. HAS ANYONE ENCOUNTERED THIS PROBLEM/ DOES ANYONE KNOW THOSE R THE SIGNS FOR getting NEW BRAKES? I am just trying to find out if the dealership is just trying to sell me new brakes or that is indeed the case.
I AM TAKING MY CAR WEDNESDAY AM SO ANY INPUT/ADVICE WOULD BE HIGHLY APPRECIATED! Thanks guys!
Old Apr 19, 2010 | 05:29 PM
sjharris's Avatar
I have replaced the brakes in my G35 when they were needed and never had any of those lights come on at the same time like you.
Sorry I could not be more help.
Old Apr 19, 2010 | 05:32 PM
djfarhan's Avatar
well apparently when they come on like that, it is a sign that they need to be replaced, according to the dealer.
thanks though
Old Apr 19, 2010 | 05:35 PM
IceMan0510's Avatar
From my understanding this occurs when a wheel speed sensor goes bad. Have not had it happen to my car but it happened to some in my family.
Old Apr 19, 2010 | 05:36 PM
djfarhan's Avatar
hmmm, thanks for the input man, i appreciate it.
Old Apr 19, 2010 | 08:35 PM
kool_yaar's Avatar
This has been discussed many times over many threads, it is your brake fluid being low, which actually means that your brake pads are in need to be replaced rather than just filling in the brake fluid which is a temporary fix.
Old Apr 19, 2010 | 08:36 PM
djfarhan's Avatar
woops, ma bad.
Old Apr 19, 2010 | 08:53 PM
kool_yaar's Avatar
No big deal maybe the moderators can sticky one of these threads and put it on the main page to help people with similar situations in the future...
Old Apr 19, 2010 | 09:03 PM
djfarhan's Avatar
they should, to me, it looked like a electronics problem...
Old Apr 19, 2010 | 09:15 PM
mishmosh's Avatar
Good explanation KoolYaar. New brakes at only 22k? Please update us if that is true.
Old Apr 19, 2010 | 09:25 PM
kool_yaar's Avatar
my first brakes set went out around 20k with a couple of track session, these new ceramic sets have been on for ~30k ans still have a lot left with no track driving
Old Apr 19, 2010 | 09:27 PM
djfarhan's Avatar
i know right, i just bought it in july, wtf
Old Apr 19, 2010 | 11:06 PM
mishmosh's Avatar
Kool Yaar... do ceramics stop as good as OE? I'm thinking about Hawk ceramics in particular.
Old Apr 20, 2010 | 01:43 AM
djfarhan's Avatar
I just checked my brake fluid and it is half full, do u think it still could be te brake fluid that if I top it to the max, it will be fine? Or would that still be a temporarty fix?
tw, quick question, I have the 100k bumper to bumper warranty on the car, do u think the pads would be covered under it? I have till Wednesday morning to know all the info. Thanks guys.
Old Apr 20, 2010 | 08:42 AM
AesonVirus's Avatar
Okay... you're a friend so I can say this.
Use the friggen search function! There have to be at least 10 threads on this exact subject.
/soapbox
Brake pads are not covered under warranty... they're a wear item, like windshield wiper blades and tires.
The brakes on the G do go pretty quickly. You can also plan on seeing the rears wear before the fronts which is also not very common. This is caused by the VDC using the rear brakes quite a bit.
Plan on spending a couple hundred per axle at the dealer... and that's if they don't touch the rotors. You can easily do the job yourself in your driveway in less than an hour.
Adding fluid is a temporary fix. You are only replacing the fluid that is now being used to push the caliper piston further out. As soon as the new pads are installed, that extra fluid will need to be removed to avoid having your reservoir being over full.
I haven't seen the Cruise light thrown into the mix yet but it makes sense. Cruise can be disabled for a number of reasons, like having the wipers on low or high, or if the ICC sensor is dirty or hit with solar glare. Having a brake problem (like low fluid) is most likely another trigger.
