V36 AWD Coilovers Finally Available - installed!
Old Jul 7, 2010 | 07:56 AM
  #166
BloNdine's Avatar
Originally Posted by soundmike
Moscow? mates? You're not Ruski are you? (my wife is, she never say "mates").
10k will work well for daily driving. From what i remember BC mentioning, if you track the car the 10k at full damper stiffness works just as well as the 12k at semi-full dampers.
I have the 12k, and originally set it to 15 clicks from hard -- man that was rough. It's now at 20 clicks (or 10 from soft) and feels so much better.
My 2c is, 10k is still sprung way more than OEM so it shouldn't matter as far as comfort goes, but you may sacrifice a little in performance.
I am Ruski))) I ment mates as all we have G35/37 )))
Okay thanks for quick reply!
So I am going to my dacha (country house) to install them! Good luck to me, hope DIY thread will help))
Old Jul 7, 2010 | 11:11 AM
  #167
Locksmith's Avatar
Have any of you guys run into issues when contacting Buddy Club directly? I msged them and some guy emailed me back saying they don't make a set at all for the 07 and up G35x allwheeldrive..... is this true?
Old Jul 7, 2010 | 11:30 AM
  #168
bsowhat1's Avatar
Are you confusing BC Racing for Buddy Club? BC is Bor-Chuann out of Taiwan.
Old Jul 7, 2010 | 11:31 AM
  #169
sunny G-35 NYC's Avatar
That not true they do make them for the 07+ AWD sedan. The thing is you would have to contact the "right" person to get some help. when i got my box it said 07+ G35x on it
Old Jul 7, 2010 | 11:37 AM
  #170
soundmike's Avatar
Correct. Please don't confuse Buddy Club for BC Racing (Bor-Chuann).
Old Jul 7, 2010 | 03:06 PM
  #171
hey mike did you resolve your problem with the rear coils. I asked my installer and he said that he removed the lining in the trunk then drilled the hole downward.
Old Jul 7, 2010 | 04:27 PM
  #172
soundmike's Avatar
Not yet but Adrian just posted a tip here. It makes a bit more sense than going through the trunk. I wonder where your installer drilled down to? You wouldn't happen to have a pic of where the hole is in your trunk, would you? That would certainly be appreciated if you did
Thanks!
Old Jul 9, 2010 | 03:33 PM
  #173
BloNdine's Avatar
Need fast reply!
Guys so I can change the stiffness by rotating the little wheel on the strut any time?
Like a 5 sec job? Without taking of the coils away from the car everytime?
sorry for noob question and my bad English, hope u get what I ment!
Old Jul 9, 2010 | 04:04 PM
  #174
soundmike's Avatar
The front, yes. For the rears, unless you find a way to route those extenders to the trunk or inside the cabin, the struts will have to come off for adjustment.
Remember, soft is "30" clicks, hard is "0" (counter-clockwise movement). BC recommends resetting to 0 and clicking up to soft from full-hard when making adjustments.
Old Jul 9, 2010 | 04:10 PM
  #175
E-Ticket Ride's Avatar
You're going to have to make a hole like that.
Old Jul 9, 2010 | 05:02 PM
  #176
BloNdine's Avatar
Ok! Got it!
One more stupid question:
But when I was counting clicks - I found that I have 32 clicks not 30 like everyone! What could it be?
Old Jul 10, 2010 | 10:01 AM
  #177
soundmike's Avatar
Guys, just an update for those interested. I raised my rears up this morning, on the 230mm springs i got it to 27" from the ground to fender line (or roughly 14.5" from fender line to center of hub) -- for me, this equates to roughly 3/4" of a drop for the rears, which is exactly where i wanted it to be!
Should be able to fix the rear alignment without a kit.
Old Aug 7, 2010 | 12:53 PM
  #178
platinumg35x's Avatar
how much of a finger gap do you have on the highest rear setting?
Old Aug 8, 2010 | 12:55 PM
  #179
soundmike's Avatar
None with my 255/40/19s. I mean, i can fit my finger in there if i have to (due to negative camber) but the space between fender line and top of tire is non-existent -- it's level with each other, if that makes any sense.
Old Aug 8, 2010 | 01:57 PM
  #180
BlueFlash's Avatar
Mike, what offset are you running? I have 245 but was thinking of going with 255, I think I have et38
