Just bought Volk 19s!
Old Apr 26, 2010 | 08:23 PM
NBYOND's Avatar
Any benefit of the extended lugs?
Old Apr 27, 2010 | 03:45 AM
Defratos's Avatar
You're Despicable
Originally Posted by Q8y_drifter
I have those same adapters and they work well. Got mine from B2Autodesign for cheaper though
Hey does everyone need these adapters when installing oem TPMS onto aftermarket wheels? because I didn't use anything, I simply swapped them over and they seem to be working just fine.
So why would we need them? and why do mine fit without an adapter?
Old Apr 27, 2010 | 12:03 PM
jran76's Avatar
Originally Posted by Judono
I picked these up for my wheels and have been riding on them for a few months without any problems.
http://cgi.ebay.com/ebaymotors/New-A...Q5fAccessories
These should work on the GTS wheels. This is basically what I am using from iForged (and they are cheaper than iForged).
Originally Posted by NBYOND
Thanks for the feedback. Did you choose the straight or the 90 degree adapters? Is that all you need, or do you need the bracket adapter as well? I want to get another set of sensors because I will need them come winter time when the wheels come off for the snow. Any idea where to get a set for cheap money? Thanks.
Either will work. Not sure where to get TPMS sensors.
You only need the adapters on 2/3 piece wheels that use a 90 degree valve stem. The OEM TPMS valve stem will work on most 1 piece wheels. A lot of 2/3 piece wheels are now drilling a second hole to run the regular 90 degree valve stem and the TPMS at the same time.
Old Apr 27, 2010 | 03:55 PM
NBYOND's Avatar
Thanks for all the feedback. Im going to grab these off ebay and give them a shot.
Last question until I get these mounted up.....what size tires should I go with? I will not be lowering the car, and I want something with a nice wide stance. My initial thought was to go with 245/40/19s, but after looking at some of you guys running 275/35/19 I'm leaning that way if possible. Will 275/35 clear on all four corners?
Old Apr 27, 2010 | 04:55 PM
elayman's Avatar
You have the sensors or the adapters, or both? haha.
just the sensors
Old Apr 27, 2010 | 05:56 PM
NBYOND's Avatar
Originally Posted by elayman
just the sensors
PMd
Old Apr 28, 2010 | 03:43 PM
NBYOND's Avatar
What do you guys recommend for tires on this setup. I was thinking 255/40 or 275/35...on all four corners, thoughts? Will either fit without rubbing issues?
Old Apr 28, 2010 | 06:46 PM
jran76's Avatar
The 275 is going to being pushing it. I would go with the 245/40 or 255/40 on the first go around. Those are closest to the stock tire size as far as diameter also.
Old Apr 28, 2010 | 06:52 PM
PhantomCoupe's Avatar
Going to look sweet man.
Old Apr 28, 2010 | 07:41 PM
NBYOND's Avatar
That's what I figured. Damn I dont know what to do. Haha.
Old Apr 29, 2010 | 07:02 PM
Jon81035's Avatar
Also, are the stock lug nuts compatible with the Volks? Is there a brand or size you guys recommend? Thanks.
I went with Rays extended. You can get in Red, Black or Blue.
And remember that if you have 2 sets of TPMS, you will need to Validate (pair) the new set to your vehicle with a special "tool" each time you change tires. Infiniti and specialty automotive shops can do it for you, or you can buy the unit for a couple hundred dollars.
Sweet Rims!
Old Apr 29, 2010 | 07:39 PM
NBYOND's Avatar
^ Thanks for the info.
I dont know what to do. If it were you guys what would you do? 255/40 or 245/40?
I'm personally leaning toward the 255/40...would like your expert opinions. Thanks.
Old Apr 29, 2010 | 07:54 PM
Jon81035's Avatar
After tons of advice I used this calulator:
http://www.miata.net/garage/tirecalc.html
and went with tires that most closely matched stock Diameter. You'll probably sweat it the whole way until you actually see them in the wells. GL!
Old Apr 29, 2010 | 10:49 PM
Shurik355's Avatar
Cool!! man I would love to see those on your car when you get them, especially when the car is gonna be dropped!!!
Old Apr 30, 2010 | 03:53 PM
  #30
NBYOND's Avatar
Thanks man, unfortunately it will be stock height for a little while until I save up some spending money.
I'm fairly certain I'm going with the 255/40 tires as well. Stock diameter is 26.74" while the 255/40s are 27.03", a 1.08% difference. Pretty damn close considering the extra sidewall and width you get compared to the 245/40 in my opinion.
