BBS RGR Diamond Black
Old May 4, 2010 | 11:11 AM
Iamtodd's Avatar
Front
• Size: 19x8.5, 18mm Offset
Rear
• Size: 19x9.5, 22mm Offset
I'm meeting up a guy who's selling it for $2,500 including Pirelli P Zero. It's pretty much mint condition, we're going to put it on this Thursday to see how it stance...
It will go on this car
Opinion please??
Here it is sorry bad quality cell camera...but yeah rear sticks out too much : ( front is perfect...need to lower though
<br>
Old May 4, 2010 | 11:12 AM
Locksmith's Avatar
They would look sick man get them!
Old May 4, 2010 | 11:34 AM
sunny G-35 NYC's Avatar
They are going to look nice. You might need to rum some negative camber to make them stick out less.
Old May 4, 2010 | 11:35 AM
AlWakRa's Avatar
subscribe ....
I want to see them on a G. I think they will look sick...
Old May 4, 2010 | 11:42 AM
Iamtodd's Avatar
Thumbs up
yeah I'm anxious to see how much it will stick out. Hopefully not too much, he had it before on his 06 Z and didn't have a problem or so he said. I'll take some pics with the rims on the car on Thursday.
Old May 4, 2010 | 11:43 AM
kool_yaar's Avatar
They should look great! I love the black mesh wheels look on the G.
Old May 4, 2010 | 11:49 AM
jran76's Avatar
Are you lowered? Do you have the ability to run -2 degrees (or more) of camber?
The only way those will fit is with some negative camber. They can definitely fit, but if you are not lowered it is not going to work. The rears will stick out about a half inch from the fender well in stock form.
Old May 4, 2010 | 11:53 AM
Iamtodd's Avatar
exactly what i don't want to hear....No i'm not lower.
Old May 4, 2010 | 12:11 PM
Im running 20x9 +25 all around and am running -1.75 degrees of negative camber to make them fit properly. you might want to lower the car after you put these on since they would stick out.
Old May 4, 2010 | 12:24 PM
Iamtodd's Avatar
Thanks guys...we'll see how it looks on Thursday.
Old May 4, 2010 | 01:40 PM
LightsOut's Avatar
SIETESG
your fronts will fit
your rears are gonna need some camber, and listen to the other guys about being lowered. your gonna need to be lowered to get them to fit properly.
your comparing a Z, which can run very low offsets to a sedan that cant.
what tire size you plan on running? cause a strectched tire is gonna be needed. Id say 245 or 255 for the rear. but I would go 245 for the 9.5 width and about almost -1.5 -2.0 degree camber
front run 225 or 235 tire on your 8.5 to keep the front stretched like the rear.
Old May 4, 2010 | 01:47 PM
Iamtodd's Avatar
he got Pirelli P zero 245 on it right now. I'm debating if i should even go and try it on...from what you guys are saying...i'd have to lower the car 1st.
Old May 4, 2010 | 01:52 PM
LightsOut's Avatar
SIETESG
if your not going to lower your car. I highly suggest doing a test fit just to show how awful the fitment is on stock height.
and if your worried about keeping your speedometer reading correctly, then your profile should be 40 for the 19's. even though 35 profile is still okay, but its not going to read correctly.
Old May 4, 2010 | 02:00 PM
Iamtodd's Avatar
Ok check back on late thursday night. I'll have some pics up.
Old May 4, 2010 | 02:06 PM
LightsOut's Avatar
SIETESG
ok will do.
