Would you switch them!!
Old Feb 26, 2011 | 09:55 PM
salvador312's Avatar
Do you have the low tire pressure light?!
Old Feb 26, 2011 | 10:02 PM
soundmike's Avatar
Yep.
Old Feb 26, 2011 | 10:33 PM
I should be good then!! Thank you Mike!!
Old Feb 27, 2011 | 12:13 AM
rustyeleio's Avatar
Another alternative is for you to bring it to a tire shop and have them check with their special TPMS tools. They can trigger the sensor to make sure they are turned on then scan for the ID. The shop may/may not be able to reprogram your ECU to the new ID numbers. If the sensor in all tires are not found, then they are dead or not present. Either way you gotta dismount the tire to fix.
I don't know if this is cheaper than just dismounting and physically checking .
There are DIY tools out there but the ones that can scan through the tire sidewall are pretty $$$. Usually you need to know the ID before mounting.
Old Apr 4, 2011 | 10:08 PM
RealMothaEffinG's Avatar
hey salvador, i also have a set of 19x8.5 and 19x9.5 wheels, do you like your tire setup? I had that on my is350 also but i was thinking of dropping down to a 235/265 respectively.
Old Apr 4, 2011 | 10:21 PM
I thought I was gonna hate it but they work for me!! They look pretty good too! I was just concern they weren't so close to OEM circumference!! I am running 245/35 and 275/30. In the future I might go 245/40 and 275/35. We'll see!
Dallsinghjr1
Sep 17, 2023 11:25 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
itgogitrev
Sep 23, 2015 07:08 PM
