caliper swap?
Old Mar 20, 2011 | 07:36 PM
InfiniteG35S's Avatar
caliper swap?
I noticed the newer brake calipers that say "Infiniti" on them have easy to access brake fluid drain valves. Does anyone know if these calipers can be put on an 07 sport sedan?
Old Mar 20, 2011 | 07:39 PM
Dubi2087's Avatar
Those are the Akebone kit you would have to buy the entire kit but you can put they will fit. You just can't take the calipers off and put them on and use you rotors and pads.
Old Mar 22, 2011 | 07:09 AM
Q8y_drifter's Avatar
You will need all 4 calipers, rotors, pads and little accessories that comes with the kit. you will also need to modify the rear dust shields to make room for the larger rotors. Other than that, the new calipers are a direct bolt-on, same mounting points, same everything.
www.conceptzperformance.com
^^ These guys carry the full kit, with options to choose from.
Old Mar 22, 2011 | 12:01 PM
Thanks all.
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Visionnn
Oct 3, 2015 05:16 AM
dcsbh1
Oct 1, 2015 03:15 PM
doakley92
Sep 25, 2015 12:58 PM
