ALL Lowered AWD people - Need alignment help
Hey everyone. Ive been lowered on Eibach springs for about a year now. I have front and rear camber kits on my AWD.
Does anyone who have an AWD sedan lowered on with camber kits having any problems with alignment? Are you able to get within OEM specs?
I got my alignment done twice now and the shop tells me that they can get the front within OEM specs but not the rear. They tell me that since my car is lowered, the camber and toe are going against each other, and can only set one of them to OEM spec. I know to set the toe to spec first before camber.
My camber is about 1.8 degrees, which is not to horrible, so I would just like to know if any other AWD are similar.
Thanks
Thanks
on
Problem solved: All you need to do is get the adjustable Toe bolt kit in the rear SPC makes it under $30. You have to reem out the original hole according to the template they give you. It gives you double the adjustment for toe in the rear. I had same issue, I spent $200 At the dealership only for them to giv eme the car back with the toe horribly off, after I took it home I adjusted everything, and ordered the Adjustabel Toe bolt kit, took me about 2 hours to do the whole thing , but man does it make it easy to do an alignment. Then took my Car to Town Fair Tire and got a $49 4 wheel alignment and it perfect now. I also have the Eibach pro kit , SPC front Control arm and SPC rear camber arm. 2008 G35XS.
I m rolling on BC Coils with SPC camber kit and my toe is back in spec but my camber isnt i m running like -.5 in the front and -1.7 in the rear but its ok cause toe is what kills the tires and plus i like the cambered look so i might throw in some more when i go lower
also +1 on the spc toe bolts not only are they cheap but super easy to install
I have the SPC kit front and rear, but I don't have the AWD. My front and rear alignment are both within factory spec.
If you bought the Eibach kit (made by SPC) there are actually 2 part numbers available for the rear kit. One is for the toe bolts. The other part number is for the camber arms AND toes bolts together.
the shop said that they could get the camber back in to spec but they said with my wheels and drop they would put in some camber to avoid rubbing and clearance issues
hey thanks for the tip. Ill have to go back to the shop where i got it installed and see if they made the holes bigger.
and i m pretty low
I'm in the same situation as the OP. X with Eibach PK and Eibach rear camber kit + toe bolts. They were only able to get my camber to -1.5 in the rear while keeping toe in spec.
I'm wondering now if the shop that installed my camber kit enlarged the holes for the toe bolts? Is it possible that even with the toe bolt kit properly installed that you still can't get camber into spec?
