Ride Quality, need everyone's opinion!
Old Jul 18, 2011 | 02:08 PM
Supremee's Avatar
Bump ^ in for pics!
Old Jul 18, 2011 | 05:43 PM
rvanderwerf's Avatar
Originally Posted by mishmosh
Ride quality shouldn't be too bad with just Eibach springs. But whatever you do, resist the temptation to get sway bars. I wish I didn't get the Hotchkis sway set. For a daily driver, there really is no reason and the ride definitely is harsher and jigglier. In fact, I recently adjusted the rear sway end link from the mid-stiff to low-stiff position and it made a huge difference in compliance. On the highway, even passenger seat vibration was reduced dramatically.
oh noes, I just signed up for the 300$ hotchkis group buy, and now I just noticed your comment. My G feels sloppy around the corners, I didn't think it would mess up my ride going in a straight line, should I get out now?
Old Jul 18, 2011 | 09:59 PM
drivethefive's Avatar
Originally Posted by BoyWonder07
Bump ^ in for pics!
Almost...
They guy I was talking to on the 370z forum was taking his sweet time answering my pm's on his forum so I just got my 370 springs last week. I will be shaving my rear spring mounts/seats this weekend and will be getting everything installed the following week!
Old Jul 18, 2011 | 10:35 PM
vqsmile's Avatar
... But whatever you do, resist the temptation to get sway bars. I wish I didn't get the Hotchkis sway set. For a daily driver, there really is no reason and the ride definitely is harsher and jigglier. In fact, I recently adjusted the rear sway end link from the mid-stiff to low-stiff position and it made a huge difference in compliance. On the highway, even passenger seat vibration was reduced dramatically.
I'd like to hear back on this too.
Old Jul 18, 2011 | 10:48 PM
lefizzet's Avatar
Eibachs aren't bad and close to a stock feel if you're on 17s with a nice 55 (or so) profile tire. But with my current setup on 20's 245/35 and 285/30 the ride is definitely much harsher than stock. I feel every little bump on the road but if you live in an area with decent roads it's not all that bad.
Old Jul 19, 2011 | 12:11 PM
soundmike's Avatar
Originally Posted by lefizzet
... but if you live in an area with decent roads it's not all that bad.
^ that's a good gauge to go by. To some degree, the stiffer sway bars acts as a way to unify the independent suspension. So, when one side moves, the other moves with it. On smooth roads, you'll track better (the main advantage of beam-type suspensions), but any dip will upset things more readily.
FWIW, i had the Eibach front sway, OEM rear sway and the 6pt brace. You feel the road more for sure. I took off the brace and the difference is very apparent... much softer. I throw this tidbit on here because the brace acts as a pseudo sway bar. I have had no reason to install the rear Eibach sway just yet, it's just sitting in the garage. But i imagine it will make the ride harsher when roads are imperfect.
Old Jul 19, 2011 | 02:47 PM
makes sense.. I did some more searching around, except for 1 guy, everyone else said it was well worth the upgrade on the sways, even on the sport version.
Old Jul 20, 2011 | 02:48 AM
harp00n's Avatar
as I know, Impuls are much more harsher then Eibach, though they offer minimal drop available.
a friend of mine took off Impuls to get Eibachs (wanted to drop it more) and now he says his ride is smoother!
Old Jul 20, 2011 | 04:04 AM
mishmosh's Avatar
That is it exactly. The sway bars act to bind the suspension and on choppy uneven surfaces, the ride can be penal.
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
jeffbdye
Jun 1, 2018 03:51 PM
prinny
Nov 22, 2015 11:07 PM
