Tire Sizing for aggressive 20's with Eibach drop
Old Oct 31, 2011 | 07:16 PM
Fumanchu's Avatar
Just want some info from the guys that are running agressive fitments on their sedans...
Looking into new rims with the following sizes;
Front: 20x8.5 +33
Rear: 20x10.5 + 30
I am currently running some MMR 19's with an Eibach drop. I only put about 4k miles a year on my car so I am not worried about running a little extra camber. My current camber settings are;
Front: -1.8
Rear: -2.0
What's the tire size I should go with? A little stretch is ok for me.
Old Nov 1, 2011 | 07:28 AM
soundmike's Avatar
FWIW, looking at my photos from this thread. You may need to stretch the rears quite a bit and/or add more camber.
My rears are rubbing with 285/30's on +45 10.5" wheels with -2ish camber. The fronts are 245/35 +24 and fits just fine IMHO.
Old Nov 1, 2011 | 07:41 AM
2fly4em's Avatar
Lets hear some more input i wanna know too
Old Nov 1, 2011 | 12:11 PM
Fumanchu's Avatar
You think a 275 rear with a tiny bit more camber would work?
Old Nov 1, 2011 | 12:26 PM
blkdragn's Avatar
I'm running a 275 on a 10.5" wheel with a +38mm offset and I don't see how a 275 tire could be ran on a +30 wheel without a decent amount of camber.
You can comfortably run a 245/35 on the fronts WITH a 15mm spacer and it should bring the wheel right to the fender. For a more aggressive fitment, you can run a 20mm spacer and run a 225/35 tire. Depending on how aggressive you'd like the set-up, you can even go with a 25mm spacer but thats up to you.
Now on to the rears, for a 10.5 wheel with a +30 offset you will need quite a stretch. I would say something like a 255 tire.
I'm not sure what look you are going for but the rears are quite aggressive compared to the fronts.
Old Nov 1, 2011 | 12:54 PM
Fumanchu's Avatar
Will the extra 8mm of offset be too much you think? What camber settings are you running in the rear? I can also run a Toyo tire to help as well as dialing my camber into the high -2's.
Old Nov 1, 2011 | 01:33 PM
Fumanchu's Avatar
This is a comparison with what I have currently and with the new wheels and 275/30/20 tires.
Attached Thumbnails Tire Sizing for aggressive 20's with Eibach drop-untitled.jpg
Old Nov 1, 2011 | 02:41 PM
blkdragn's Avatar
I was recently thinking about going an extra 5mm and going from 275/30 to 255/35. That would be at +33mm and I was expecting to camber the rears even more.
I'll try to post a good pic of my set-up when I get home from work later!
Old Nov 2, 2011 | 07:25 PM
Fumanchu's Avatar
I've seen 255's on a 10.5 and it looks too stretched for me. I would do a 265 if I could make it work
Old Nov 8, 2011 | 02:45 PM
Fumanchu's Avatar
https://g35driver.com/forums/showthr...09#post6203809
Here is a 1st gen sedan running the same setup but he had to camber the rear to -3.5. Will the 2nd gen sedan have to run that much camber.
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
Jnm07
Aug 6, 2015 03:03 AM
reaper76
Aug 5, 2015 10:13 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
