Front end clunking noise
Old Mar 20, 2014 | 03:57 PM
PSG35's Avatar
Apologies if this has been posted before, but I couldn't find what I was looking for on a search.
My 2007 G35x has an occasional clunking noise when going over bumps. Just had it into the local Nissan shop (they are much closer than Infiniti) to have a look. They said this is reminiscent of the known issue with the 2003-06 G35 but since the 2007 has no compression rod it is not that. Everything associated with the bushings and frame are fine. They had two 30+ year experienced mechanics driving it around for hours with the chassis ears (?) on and could not figure it out.
The noise is predominantly on the driver's side. I did hit a deer on the passenger front 6 months ago and had it repaired at a collision shop. I suppose this could have created the issue, but the mechanics' only thought after checking everything out was that maybe the noise was some metal flexing rather than anything broken.
Any ideas or recommendations would be welcomed. Thanks.
Old Mar 22, 2014 | 07:29 PM
terrycs's Avatar
My guess is the sway bar end links. You can't tell when the bushings inside those things go bad just by looking.
Old Mar 22, 2014 | 08:19 PM
itztwinki3's Avatar
you can checks these.
1. sway bar bushings.(most common in many cars)
2. sway bar links
3. struts.
5. control arm bushings.
Old Apr 4, 2014 | 01:48 PM
PSG35's Avatar
Many thanks for your replies. Unfortunately all the possibilities noted so far were already checked and cleared as not the culprit.
Old May 29, 2014 | 12:12 AM
prelude9569's Avatar
Did you get this fixed? I'm chasing a clunking noise myself. It's enough to make you want to sell the car.
Old May 29, 2014 | 07:41 AM
PSG35's Avatar
Unfortunately, i've been so busy that I have not had it in to be looked at further much less fixed. Fortunately, however, with the warmer weather finally making its way to the midwest, the noise is barely noticeable now compared to when it was -10 degrees.
rezendvous420
May 31, 2020 01:26 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
atk08
Jul 30, 2015 03:12 PM
newg37
Jul 26, 2015 09:32 AM
cyrus32
Jul 18, 2015 06:22 PM
