Rear brake dust shield
Old May 21, 2016 | 09:12 AM
celwin's Avatar
Has anyone successfully remove the rear brake dust shields? I would rather replace it than cut it for Akebono install.
Old May 21, 2016 | 01:14 PM
vqsmile's Avatar
Sure, they can be removed, but only after you disconnect the axle and pull the wheel bearing/hub assembly from the axle housing to get at it. It's shown clearly in the part breakdown: (see page RAX-7)
http://www.nicoclub.com/FSM/G35/Sedan/2008/RAX.pdf
Old May 24, 2016 | 09:16 AM
celwin's Avatar
I know. I wanted feedback from someone who has actually done it. To gauge time and effort it too.
Old May 24, 2016 | 09:33 AM
LoSt180's Avatar
You can't completely remove the dust shield. The e-brake hardware mounts to the shield. You do need to remove the wheel hubs to remove the shields, and that involves dropping the axles. I recently replaced my wheel bearings and did the e-brake pads and hardware while it was all apart.
Personally I would just get some G37S dust shields to avoid cutting and have a cleaner install. Just depends on how much effort you want to put into it.
Lolik0
May 7, 2016 03:15 PM
LemonStain
May 4, 2016 11:06 PM
ninjabong
May 4, 2016 05:17 PM
guzanote
Apr 25, 2016 01:01 PM
dundermifflin99
Apr 23, 2016 12:23 PM
