DIY: Oil Change
Old Mar 7, 2012 | 10:03 PM
  #91
salvador312's Avatar
anyone else??
Old Mar 8, 2012 | 02:00 AM
  #92
vqsmile's Avatar
Originally Posted by salvador312
About to go buy the ficking oil vqsmile!! What brand exactly do you recommend on the oil! I want to go synthetic? Help me out here! I don't know if weather has anything to do with it but you know the weather in Los Angeles is always great!
Sorry Sal, been away all day today.
I usually just go with the regular Mobil 1 5w-30 when it's on sale in quantities at either Costco or Walmart. It's not that I think the M1 is the the absolute end-all as far as oils go; it's more that I really don't think it matters as much as you'd think from all the hype people put into the debates. If you are using a reasonably good, name brand synthetic, you're gonna be fine. Save yourself the worry, your car will NOT be prematurely entering the junkyard due to poor lubrication issues. The rest is pretty much all hype; PERIOD!
btw, there is nothing wrong with dino oil either, providing it's changed more frequently, it will do just as well. I just prefer not to change my oil as often is all.
Old Mar 8, 2012 | 07:46 AM
  #93
soundmike's Avatar
I agree, pretty much any oil these days will work fine for the HR's -- it all depends on frequency of the change and how much stress you're putting on the engine and fluids.
I personally use M1-EP, i need to update my UOA results thread soon, it's missing an entry or two, but you should get an idea for how it's performing.
https://g35driver.com/forums/v36-eng...g-results.html
Old Mar 11, 2012 | 07:08 PM
  #94
What do you Gus think?!
Old Mar 11, 2012 | 09:05 PM
  #95
vqsmile's Avatar
^^ That's fine Sal, but it's probably about $10 cheaper at Walmart.
(you're stressing waaaaay to much over this man)
Old Mar 11, 2012 | 09:48 PM
  #96
HAHAHAh, okay! I should go to Walmart tomorrow then! I am installing my Test Pipes tomorrow so I am gonna be under the car! It's a win win!
Old Mar 14, 2012 | 01:14 PM
  #97
rvanderwerf's Avatar
good luck on the test pipes, they are very tough!! The place I took it to broke 2 bolts getting my old ones off. It's definately something I would pay someone for
Old Mar 14, 2012 | 01:35 PM
  #98
I got extra bolts! I have heard they are b1tch to do them! I got the tools and the skills! I just lack the time! I need the whole day just in case I encounter any complications! I did my Akebonos and that wasn't easy at all!
Old Dec 4, 2012 | 11:18 AM
  #99
Davidle92's Avatar
Lightbulb
Are these crush washers worth getting? Im tryna get ready for my first oil change.
Old Dec 4, 2012 | 11:23 AM
  #100
Davidle92's Avatar
http://www.ebay.com/itm/Lot-of-10PC-...c751d9&vxp=mtr
are these okay?
Old Dec 4, 2012 | 12:25 PM
  #101
vqsmile's Avatar
Originally Posted by Davidle92
Those are fine.
Old Sep 17, 2014 | 02:17 PM
  #102
skiloads's Avatar
Larger oil filter that works with the VQ35HR engine
I was poking around the V36 DIY threads recently because I posted a DIY fog light to DRL for the V36 with A/T and read through the oil change posts. Apparently no one in this thread noted it, but about two years ago I posted elsewhere in the 35driver.com forums that as soon as I got my 2007 G35X I felt that the stock oil filter on the VQ35HR engine was way too small. I couldn’t understand why, because there’s plenty of room down there. I did the research and found the largest oil filter that fits this engine with the proper thread, gasket and oil bypass specs. I’ve been running with the larger oil filter for three years now. I usually get the PureOne, but I look for sales and use the M1-207 when I can.
Here’s a listing of larger oil filters that fit the VQ35HR engine.
Purolator PureOne: PL14619
K&N: HP-2007
Napa: 1324
Wix: 51324
Mobil: M1-207
Bosch: 3401
Old Sep 17, 2014 | 02:53 PM
  #103
vqsmile's Avatar
Originally Posted by skiloads
I couldn’t understand why, because there’s plenty of room down there. ...
Exactly!
I have always suspected there was a perfectly good reason the Nissan engineers deliberately selected the filter size they did, and that it wasn't merely because of economy or to better suit little hands. My guess is it has something to do with issues like maintaining proper oil pressure, minimizing potential drain-back consequences after long term sititng, etc., etc..
I too was initially concerned about filter sizing, and actually cut open a few filters after a 7500 mile OCI, but was relieved to find the filter media still in very good condition; not at all saturated with residue. I concluded the size must therefore be adequate for at least as long as I'd ever run without a filter change. So, rather than second guess at what the engineers intended, I'll just keep running the original size. (NOTE: if you go to WIX site, they will also spec a small size filter, even though they theoretically know perfectly well which of their filters can fit.)
That being said, I know lot of people run a larger filter without any apparent consequences, so it isn't like anything radical is going to happen with running a larger filter. I just question the long term effects and wonder if any potential benefits outweigh potential concerns. For me, they don't, but YMMV.
Old Sep 18, 2014 | 07:17 PM
  #104
blnewt's Avatar
I've used the bigger filters for the M45/M56 for several years now, my Blackstones w/ Synthetic at 6-7k OCI have been very good. This is w/ my 07 G35 and my current G37.
Currently I'm using Wix 57356 (since they had a killer pkg deal @ O'Reillys a while back.)
zoop425
Mar 29, 2016 05:51 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
