DIY: Installing Sport paddles
Rating: Thread Rating: 3 votes, 5.00 average.
Old Feb 1, 2013 | 05:40 PM
  #361
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
Originally Posted by turrific
Of really? Thanks Phil. Where are you located? I may just order from you if that can work.
I presume the silver paddles would be fine in a black/charcoal interior. Does anyone have pics or a part number for the silver paddles?
Yeah, they are silver, with a slight greyish/beige finish to them,
25549-JK10A
Old Feb 1, 2013 | 05:44 PM
  #362
turrific's Avatar
Thanks. Color look something like this?
http://i1022.photobucket.com/albums/.../DSC07042s.jpg
Old Feb 1, 2013 | 05:51 PM
  #363
PREMIUM SPONSOR
Precicsely,
see that little trim under the silver? that's the part that instead of being black, would be the willow (dingy grey/beige) color
Old Feb 1, 2013 | 07:30 PM
  #364
pattyballs's Avatar
^phil, that prive is with the grey interior steering colum covers? Or are the paddles just a different color but can still be had with the black interior peices?
Old Feb 4, 2013 | 10:28 AM
  #365
PREMIUM SPONSOR
That's correct, the black column peices would still be part of this price
Old Mar 10, 2013 | 07:18 PM
  #366
turrific's Avatar
I installed the paddles this weekend. Thanks for the parts, Phil and thanks to the OP for the DIY. I opted to not remove the steering wheel, which required a little more effort to remove the lower plastic trim.
Old Mar 16, 2013 | 04:02 PM
  #367
JFletch's Avatar
Is this mod compatable with an '03 sedan???
Old Mar 16, 2013 | 11:55 PM
  #368
vqsmile's Avatar
Why would you think it would be? Does the '03 have the same transmission, same steering column, same wiring, same ecu, same . . . ???
Old Mar 29, 2013 | 01:19 PM
  #369
nbhms's Avatar
Need verification please
I have a Canadian '08 G35x sedan, and would like to do this mod. Having seen in the thread that some base 08 models did not have the connectors, I took my lower column cover off to check. I've found two connectors taped up like the OP mentions. However, while they look similar, they are not identical (to each other). I've seen several posts in this thread that seem to indicate that they are identical, so I just want to verify before purchasing the kit that I have the proper connectors. Pictures below.
Attached Thumbnails DIY: Installing Sport paddles-p1020290.jpg   DIY: Installing Sport paddles-p1020293.jpg   DIY: Installing Sport paddles-p1020294.jpg
Old Mar 29, 2013 | 01:22 PM
  #370
G3Sx's Avatar
Go for it. Your car is pre-wired. The connectors are not identical to prevent the downshift plug being inserted into the upshift paddle.
Old May 29, 2013 | 10:00 PM
  #371
boostd7's Avatar
does this mod shift faster than using the auto ****? other wise i wont' do it/ thanks.
Old May 29, 2013 | 11:50 PM
  #372
vqsmile's Avatar
^^ wouldn't the electrons actually have farther to travel?
Old May 30, 2013 | 08:12 AM
  #373
Phil_I's Avatar
Nope, it's the same response time as using the console shifter.
Old May 7, 2014 | 11:00 PM
  #374
xxx4reggie's Avatar
question for you. will this fit a 2010 g37 non s?
is there a easy way to find out without opening things up?
Old Jan 25, 2016 | 02:56 PM
  #375
marchettiauto's Avatar
Paddles for 07 G35x
I live in Toronto Canada, and have a 2007 G35x with premium package and nav. Can I still buy this anywhere? Would I need to do any cutting or trimming or ordering of new trim pieces? Or, do i just order the paddles and plug them in basically? Thanks
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
