DIY: Coilover Install
Old Aug 12, 2009 | 11:17 AM
  #31
Dubi2087's Avatar
Originally Posted by E-Ticket Ride
Sorry, didn't see your question. The answer is no, refer to this pic (the first time I installed it, we did it wrong):
**EDIT**
I should specify that you will not use the rubber cone with coil overs, but you will use them when doing just a spring change.
This is the wrong way to mount the rears:
is this the same for the coupes.
Old Aug 12, 2009 | 11:33 AM
  #32
InTgr8r's Avatar
Staff ALUMNI (retired)
Yes.
..the 2nd Gen coupes (G37) are exactly the same.
IDK about 1st gen coupes.
Old Aug 12, 2009 | 03:03 PM
  #33
E-Ticket Ride's Avatar
Originally Posted by InTgr8r
Thanks San
I received this set up info from JIC-Magic tech support,
which seems like a logical procedure to keep damper stroke near max. length.
1. Adjust the spring height FIRST.
2. after your spring ride height^ is set, adjust the damper length.
- place car on jack stands
- measure height to bottom of spring cup
- with a floor jack raise the spring cup 10mm (pre-load)
- adjust the damper length to fit this position.
Good info, added to OP.
  #34
Thanks San
Old Apr 27, 2010 | 03:10 AM
  #35
PoorG35's Avatar
The fronts were completely different on my 03 with brembos, way more difficult, but your thread got me there and i appreciate it!
edit, and it makes sense since this isnt a vq35 LOL Damnnn
Old Apr 27, 2010 | 11:45 AM
  #36
ckp's Avatar
ckp
how long did this install take?
Old Apr 27, 2010 | 02:38 PM
  #37
ShanesG's Avatar
its a good 2-3 hr install depending on the person. +up to another hour if you're doing adjustments.
Old May 18, 2010 | 08:41 PM
  #38
Killason's Avatar
Is there anyway to add the torque specs to this DIY?
Old May 28, 2010 | 08:47 PM
  #39
parhamm1's Avatar
Can someone point me in the right direction on how to mount the rear spring perch on oem style rear coils? The rubber cone just basically pops off and I couldn't find a way to install the spring perch...
Old May 28, 2010 | 09:03 PM
  #40
If you're setup is like this, I used a rubber mallet to pound it in there. Also, get one edge of the perch as flush as you can get it then pound on the opposite side.
Old May 28, 2010 | 10:05 PM
  #41
tbrillz35's Avatar
subscribed for (hopefully near) future use.
Old May 29, 2010 | 12:26 AM
  #42
parhamm1's Avatar
I feel like the area for the spring perch (replacing the rubber cone) is so shallow and it would just fall out...
Old May 29, 2010 | 12:28 AM
  #43
parhamm1's Avatar
I tried placing the spring perch up there and I just didn't see any particular way it would stay up there flush.... idk.
Old May 29, 2010 | 01:04 AM
  #44
Shurik355's Avatar
Great! JICs huh! I was thinking if dropping mine to go with TEIN SS coilovers (great coils). There is no way I'm going springs and shocks drop like i did with my Nissan Maxima.
SO how do you honestly like the ride quality?
Old May 29, 2010 | 02:45 AM
  #45
There are 3 or 4 small metal clips that hold the perch on once you pound it in. If you remov the cone you can feel them with your fingertips
