DIY: Coilover Install
Old Feb 4, 2012 | 02:45 PM
  #91
xfuz1on's Avatar
Not to sound ignorant, but what exactly is preload and how do I set it? Thanks
Old Apr 9, 2012 | 03:06 PM
  #92
ManE-G35's Avatar
subscribed
Old May 14, 2012 | 01:02 PM
  #93
Elmecano's Avatar
Hi guys just a quick question when you said:
1. Adjust the spring height FIRST.
2. after your spring ride height^ is set, adjust the damper length.
- place car on jack stands
- measure height to bottom of spring cup
- with a floor jack raise the spring cup 10mm (pre-load)
- adjust the damper length to fit this position.
so when you adjust the spring height do you lower the car on ground with or without the damper??
thanks
Old May 23, 2012 | 07:03 PM
  #94
desii's Avatar
how do you guys know when to reuse to top rear spring mount?
i have function form type 2 and ive seen pictures of both rear mount and with out?
im confused
EDIT:
not looking to slam my car either, jsut 1 finger gap all the way around
Old Oct 3, 2012 | 05:01 PM
  #95
blnewt's Avatar
Thanks for the clear DIY OP, can't wait to install mine this weekend. With the pillow-ball top plates should make this much easier than changing out my lowering springs
Old Oct 25, 2012 | 03:29 PM
  #96
Jetfire's Avatar
thanks
No the damper should already be installed on the vehicle by then.
Old Jan 29, 2013 | 12:44 PM
  #97
kdawg8526's Avatar
thanks for the writeup it was realy helpful
Old Jan 29, 2013 | 03:10 PM
  #98
E-Ticket Ride's Avatar
Glad it helped!
Old Apr 19, 2013 | 11:16 PM
  #99
PhillyLurk's Avatar
nice write up. and to my understanding i jack up the spring cup until the spring has no more play then another 10mm up? then i adjust the strut to that exact position?
Old Apr 20, 2013 | 12:51 AM
  #100
blnewt's Avatar
correct
Just remember to preload it again if you have to do any height adjustments back there.
Old Apr 20, 2013 | 11:03 AM
  #101
PhillyLurk's Avatar
Originally Posted by blnewt
correct
thanks! i did it wrong before and just kept jacking it up to meet the strut lol
Old Apr 20, 2013 | 07:36 PM
  #102
PhillyLurk's Avatar
having a hard time with the fronts. will a spring compressor make it easier?
Old Sep 27, 2013 | 03:18 PM
  #103
SVT's Avatar
SVT
How much different is doing this install on a 2003 year? I'm gonna do this for a buddy and this write up is great, just want to know what will be different since his is 03. Thanks.
Old Sep 27, 2013 | 06:11 PM
  #104
vqsmile's Avatar
Why not just go to the appropriate forum section for that car (ie. the V35 first gen sections) and do a simple search there. There's got to be tons of DIY info posted on a 10 year old car.
Old Nov 12, 2013 | 09:41 PM
  #105
blubox's Avatar
Nice write up!!! thanks
