DIY: Clean your throttle bodies
#166
Having the same problem as who4ever. Will give the reset procedure a few more try before giving up and going to the dealership. What is MIL in the description btw?
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops blinking and turned ON.
#169
who4ever, did the dealership find anything wrong or where they able reset your throttle and everything turned out fine? I have the same problem as your your youtube videos and have tried the reset procedure for 3 hours straight and think I killed my battery.
#170
But problem not solved
i talk to engineer he said he did the procedure with CONCULT But problem still there
He said he will work on that to get solve .
I hope is not cost me to buy new throttle
#171
I really hope you get things solved, btw trying pedal to the metal for a few runs, it fixed mine, as i always get 2k rpm after each time i clean my TB, but it goes after cruising around and got WOT with it.
#174
#175
#177
^ in all honesty we cant really help you other than to tell you to do the procedure again or have someone in your area from the forums try for you like i said before, other than that i think you will have to put in the effort to take off your intake and take your car to the dealer for the reset as they requested.
#179
#180
