intake Messed up my windows?
Old Sep 20, 2007 | 02:11 PM
dam0fo's Avatar
when i instaled my intake i guess it messed up my auto windows not when they go down but when i try and make them autmatically go up! i remember hearing something about this. how do i fix it?
Old Sep 20, 2007 | 02:28 PM
qruG35's Avatar
Not knocking you, but how in thee HELL does installing an aftermarket intake affect power windows??? It must be a coincidence that they failed at the time you installed the intake.....
Old Sep 20, 2007 | 02:40 PM
Lords47's Avatar
Oh! This happened to me. There was a fix listed in the service manual I believe. But you need to reset the auto-up feature. Press and hold the window up button, and hold it up for I think it said 3-5 seconds after the window is already up. This should reset it.
Old Sep 20, 2007 | 02:46 PM
CalsonicVQ's Avatar
I don't know what the intake installation entails, but did you disconnect the battery for any reason? According the Power Window Control section of the service manual, you are supposed to initialize the auto/anti-pinch system after the window harness is disconnected or if you disconnect the battery.
Old Sep 20, 2007 | 02:51 PM
GreenGoblin's Avatar
The goblin resurrection
ya seems to be that the battery was disconected and now the auto needs to be reset
Old Sep 20, 2007 | 08:55 PM
logik05se's Avatar
same thing happened to me....problem was the friggin intake was so loud it broke the switch.
just reset it youll be fine lol.
Old Sep 21, 2007 | 12:00 AM
Goodstuff's Avatar
Hold the buttons all the way down for 10 seconds and then all the way up for 10 seconds.
Old Oct 20, 2007 | 06:15 PM
hrp783's Avatar
thank god for search I had the problem windows would go down but not go up auto
Old Oct 20, 2007 | 06:29 PM
hrp783's Avatar
I read the manual it says "open window half way and hold the up switch untill window closes the keep holding for 3 secs. Test it and should work
itgogitrev
Sep 23, 2015 07:08 PM
Paragham
Sep 15, 2015 12:04 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
