Help with Fijita Intake
Old Nov 4, 2007 | 12:24 AM
u4528010's Avatar
Sorry for having to post here
Please help me here guys
I installed Fijita Intake and when I turned the engine on the engine chokes and the rpm dropped below 1000rpm. I tried to push the gas pedal but it did not make and better. The engine does not seem to have any power to start. What is wrong??? I followed every steps in the instructions. I need to use my car tomorrow
Do I need to remove negative side of the battery??? I did not do that.
Old Nov 4, 2007 | 02:56 AM
G35PS's Avatar
Reset ECU.
Old Nov 4, 2007 | 03:07 AM
u4528010's Avatar
How to do that?
Old Nov 5, 2007 | 09:48 AM
Cyanide Ride's Avatar
Disconnect the negative cable going to your battery.
Let sit for an hour or two? I disconnected mine during my install, took me about an hour and a half.
Started it up, no problems with running and no codes.
Check to see if your MAF's are installed correctly as well.
Old Nov 5, 2007 | 10:35 AM
dofu's Avatar
20 Year Member
Check the vacuum hosing - the black rubber hoses. Make sure they're on and clamped down.
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
vamarris
Sep 26, 2015 12:56 PM
