custom axle-back exhaust v2.0
Old Mar 20, 2008 | 08:38 PM
Cali G's Avatar
Here are some pics of the straight pipe axle-back I had fabricated. Excuse the dirty pics... no time for a rinse after work today.
It uses the stock flange/clamp and the stock hangers.
This version is for sale for $375 if anyone is interested.
Old Mar 21, 2008 | 01:03 AM
MiniRX7's Avatar
Did you say $375 for a pair of just pipes?
Thats really expensive dont you think?
What you have is a muffler elimination kit. Look up Blastin Bob's which they make for hemi powered LX cars. Their kit with polished 3.5" tips costs about $120 brand new!!
Old Mar 21, 2008 | 01:56 AM
Jspeed's Avatar
CV35 6MT
This can't be good for the aerodynamics. Maybe a panel can be used to cover up the void.
Old Mar 21, 2008 | 02:07 AM
O HELLA JDM's Avatar
post some exhaust vids
Old Mar 21, 2008 | 10:28 AM
Cali G's Avatar
The flange on these cars isn't the easiest to duplicate. If you can get it done cheaper, you're welcome to try. This doesn't require any modification of the stock exhaust and bolts in and out in about 10 min.
Old Mar 21, 2008 | 10:30 AM
Cali G's Avatar
Originally Posted by Escondido G35
Have you checked you quarter mile ET since this mod? Do you think the loss of torque is going to drop your ET's?
Keith
My times were done w/ the mufflers completely removed and no straight pipes. Also, the HKS axle back exhaust showed a 5whp gain according to HKS.. I'd imagine the flow is similar since that's a straight through 'turbo' muffler.
Old Mar 21, 2008 | 10:33 AM
Cali G's Avatar
I'm at work so I can't link youtube videos... but search for the user Turbotuner20v. I've got 3 videos up.
1 - My first dyno, 100% stock
2 - The exhaust with no mufflers (sounds the same as the straight pipes)
3 - The exhaust on a flyby
You can also try the sound in your own garage by just unbolting the stock mufflers. It takes about 20 minutes w/ a 12mm socket and if you're not lowered, you don't even need a jack.
Old Mar 21, 2008 | 03:24 PM
MiniRX7's Avatar
Can't wait to hear what this bad boy sounds like!!
Old Mar 21, 2008 | 03:43 PM
Cali G's Avatar
for some reason they jacked up our firewall while changing settings... so here's the youtube links to make things easier:
1 -
2 -
3 -
Old Mar 22, 2008 | 07:34 PM
Cali G's Avatar
I just made an appointment to dyno on April 5th and will do a set of dynos w/ the stock mufflers on, then another 3 with the stock mufflers removed. Same day/dyno within an hour of eachother.
Old Mar 23, 2008 | 05:53 PM
Beebo's Avatar
sounds very good...
Old Mar 28, 2008 | 05:51 PM
rocaveli's Avatar
video sounds great, but it's not clear enough.. you need more videos for sure
Old Mar 28, 2008 | 06:36 PM
Cali G's Avatar
what else is needed?
Old Mar 28, 2008 | 06:39 PM
rocaveli's Avatar
better, longer videos. i particularly liked these videos from a fellow forum member:
HTML Code:
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/Q0jGC0i26_c&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/Q0jGC0i26_c&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
EDIT: how the hell do u embed youtube videos?? the address is http://www.youtube.com/v/Q0jGC0i26_c&hl=en
Old Mar 28, 2008 | 07:21 PM
Cali G's Avatar
HTML Code:
alright... well I don't have many friends who are into cars and willing to go out and just video my car driving around, so that's probably all I can provide. If you're curious what it sounds like you can unbolt your mufflers w/ a few minutes work.
