Does anyone know if the G37 Exhaust bolts directly on to 2nd G35s?
Old Apr 10, 2008 | 05:11 PM
Domesticdemon's Avatar
Originally Posted by dofu
The new sedans are dual exhaust unlike the first gens. First gen coupe mid-pipe fits the first gen sedans fine, all that matters is if the new axleback fits the new sedan or not... Give it a try and let us know.
+1
Old Apr 10, 2008 | 06:14 PM
brownfv's Avatar
What is the piping diameter on the g37 exhaust system?
Old Apr 10, 2008 | 06:24 PM
g35_6gear's Avatar
Pretty small...maybe down to 2" in front of the mufflers for more ground clearance as it passes under the rear subframe by the rear differential.
Old Apr 11, 2008 | 12:02 AM
Stealthcords's Avatar
I've asked this in the past, since I would LOVE to have the G37 exhaust on my sedan.
The answer, that I heard, is the exhaust on sedan runs length wise of the car, the G37's runs width wise.
<shrug>
Old Apr 11, 2008 | 12:04 AM
Here you go:
https://g35driver.com/forums/showthr...t=stealthcords
Old Apr 11, 2008 | 02:04 AM
dofu's Avatar
20 Year Member
<shrug>
I'm thinking that since the new sedans are dual exhaust like the coupes, at the worst, it's nothing a little modification can't fix. If the piping for the sedan is a bit longer, extend it like the Z midpipe fitted on a G (Nismo exhaust comes to mind here). And if it's the shape of the piping on the axleback that doesn't work, cut out the piping and redo it... probably about $100 of work at a good exhaust shop.
But then again, I don't have a new gen sedan or coupe, and I'm not famniliar with their parts so I can't really say... Anybody got pictures of the two to kind of compare?
Old Apr 11, 2008 | 09:18 AM
blkdragn's Avatar
Originally Posted by paulg35s
Umm.. the number of doors have no bearing on whether an exhaust is going to fit on a car or not. Perfect examples are Subarus... the exhausts are the same from 1998 - 2005 for all the different body styles including the 2dr coupes, the 2.5rs and even the STIs.
Does anyone actually know?
Im not sure where you might be getting this information from but I work on Subaru's on a normal basis and their exhausts are NOT interchangeable from 98-2005 2dr or 4dr. As you can see from their different Part #s from Greddy:
Greddy Evo2 Exhaust System: 10166603
Model:IMPREZA WRX
Year:2002-05
Notes:80mm, also fits wagon / remove dif. protector
Greddy Evo2 Exhaust System: 10166601
Model:IMPREZA 2.5RS
Year:1998-01
I think for the trouble you might need to go through in order to get that G37 exhaust bolted onto your sedan, you might as well upgrade the entire thing to something like a FI or Stillen Unit. Thats if and only if you're going to end up paying $$ for a G37 exhaust and then pay more $$ to modify it. If its free, more power to you....
Allan
Old Apr 11, 2008 | 11:28 AM
paulg35s's Avatar
The reason the part numbers are different is probably the diameter of the pipes. The 2.5rs's are na and require a smaller diameter than the turbo charged wrx's/sti's
I know this because I fit an STI exhaust on my 2.5RS.
The main point of the post is to show that the 2dr and 4dr GC's could share exhausts.
Old Apr 11, 2008 | 12:16 PM
da mayor's Avatar
the sedan has a bigger trunk and when you look under the car you'll see there isn't any room like the coupe has to place the muffler in the center.
Old Apr 11, 2008 | 12:23 PM
imminence's Avatar
Yup. That's exactly what I was trying to say in my post. Also, I believe the OEM G37 muffler bolts onto the OEM mid-pipe, whereas the OEM 2nd gen sedan muffler slips onto the OEM midpipe and fastens with a clamp.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
TinoNT
Jul 24, 2015 12:16 PM
Karnicle
Jul 23, 2015 05:08 AM
si_driver
Jul 14, 2015 12:29 PM
