Crank/Underdrive pulley
Old Apr 16, 2010 | 05:45 AM
  #31
Q8y_drifter's Avatar
Has anyone seen the dyno graph on UR's website? That's a scary AFR!
Old Apr 16, 2010 | 07:24 AM
  #32
jwrape's Avatar
You might wanna re-torque the crank bolt after a little bit of driving. My Stock OEM pulley came off and with it detroyed the key on the crank shaft and spun my crank bending all the valves just a month ago or so. I had to replace my motor. There had not been any work done on the lower end of the car at all. It just came loose. Weird I thought.
Here are the pics as I was removing the motor.
and then the re-install with a new undersdrive pulley. I torqued the he!! out of that bolt....I pray it doesn't ever come back off.
Old Apr 21, 2010 | 09:58 AM
  #33
arsine's Avatar
ati crank pulleys are dampened, but they are a bit pricey
Old May 5, 2010 | 03:48 AM
  #34
chinaxinsanity's Avatar
i have the stillen pulleys. can say that when i got them, i definitely felt an increase in HP. 2nd gear just pulls on you, its awesome
,... but now that im used to it, my car feels slow again
Old May 6, 2010 | 03:48 AM
  #35
Defratos's Avatar
You're Despicable
BTW Do u need to remove the engine to install these pulleys?
Old May 6, 2010 | 05:37 AM
  #36
No, you can reach the crank pulley bolt from under the car.
Old May 6, 2010 | 06:23 AM
  #37
herrschaft's Avatar
I had a before and after dyno when my UR underdrive pulleys were installed and the shop said that there were no gains.
Old May 6, 2010 | 06:28 AM
  #38
Defratos's Avatar
You're Despicable
^ so what's the point in the first place?
Old May 6, 2010 | 06:34 AM
  #39
herrschaft's Avatar
didnt do the dyno after the install because per UR that results will show after 5-7 days or 200miles where maximum hp will be gained.
^I won't be able to dyno my car till 3 weeks from now. I'll post the results on here.
Old May 6, 2010 | 06:46 PM
  #40
Defratos's Avatar
You're Despicable
Cool looking forward to it
Old May 7, 2010 | 02:02 PM
  #41
G-Man.usa's Avatar
The lower the inertia of a rotating object, the easier it is to spin. Imagine if I put carbon fiber wheels on you bicycle - you still have the same power but you're going to get going a lot quicker. The down side is that as soon as you stop pedaling you lose momentum quicker.
Same idea behind lighter flywheels and wheels.
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
NailBomb
Oct 28, 2015 07:53 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
