My morning at . GTM!
Jun 30, 2008 | 12:59 AM
  #61
Quote: 3rd gen? It's only 2nd gen.
I thought the 2005-2006 was the 2nd gen?
Reply 0
Jun 30, 2008 | 01:07 AM
  #62
They are still considered as 1st gen.
07+ are the true 2nd gens.
maybe you can consider those as 1.5 gen.
Reply 0
Jun 30, 2008 | 01:09 AM
  #63
Nice, I want to see the HR boosted!
Reply 0
Jun 30, 2008 | 01:11 AM
  #64
Either one Whatever
I just want to see what it can do with a stock block
Reply 0
Jun 30, 2008 | 12:17 PM
  #65
YESSSSSSSSSS!
i plan on this for sure!
how do they think the 5at tranny will hold up? is it just gonna be a fluid and valve body upgrade for it?
this graph makes me tingle
Reply 0
Jun 30, 2008 | 03:46 PM
  #66
I was told the 5AT should hold up fine as long as I don't track the car every weekend. But to make the trans more reliable in the long run, they recommend a valve body upgrade and a trans cooler. Since I won't be tracking my car (more than once ?), there is no rush on the VB upgrade, but I'm probably gonna have them go ahead with the trans cooler.
My priority is on reliability which is why my car will only see 6-8 PSI. Hopefully that will come out to around 400 WHP. You can install a boost controller if you ever want to dial it up a little more, or upgrade to stage 2, 3, or even stage 4 from the start.
Reply 0
Jun 30, 2008 | 04:35 PM
  #67
Well, now I know what I want for my birthday next year.
Quote: I was told the 5AT should hold up fine as long as I don't track the car every weekend. But to make the trans more reliable in the long run, they recommend a valve body upgrade and a trans cooler. Since I won't be tracking my car (more than once ?), there is no rush on the VB upgrade, but I'm probably gonna have them go ahead with the trans cooler.
Reply 0
Jun 30, 2008 | 04:52 PM
  #68
I'm really impressed with the lower end of this block. That is one of the beefiest mains I've ever seen.
Reply 0
Jun 30, 2008 | 06:33 PM
  #69
Mod your bumper so you can run coolers on the side like these.
Engine oil
Trans fluid
Reply 0
Jul 1, 2008 | 05:02 PM
  #70
Get a trans cooler most definitely, and if I were you, dont hesitate on the vb upgrade or wait, DO IT!!!!!! You're not going to do it now, you're going to do it laaaaaater, you don't have to take word for it
Reply 0
Jul 1, 2008 | 05:06 PM
  #71
The VB helps with shifting and not hitting the rev limiter. Do the 07+ sedan autos shift pretty smoothly? They've gotten better from 03-04-05 and up. I haven't seen a FSM to see the part numbers for the transmissions.
Reply 0
Jul 1, 2008 | 05:08 PM
  #72
Sam told me it was the same one used in the Titan and FX with changes to ratios.
Quote: The VB helps with shifting and not hitting the rev limiter. Do the 07+ sedan autos shift pretty smoothly? They've gotten better from 03-04-05 and up. I haven't seen a FSM to see the part numbers for the transmissions.
Reply 0
Jul 1, 2008 | 05:11 PM
  #73
Than I'd wait on VB until you get it back. Fluid temps are the big thing when banging against the rev limiter is not the highest priority. I'm sure they can do a technosquare L-spec flash to bump the rev limiter and stuff.
Reply 0
Jul 1, 2008 | 05:13 PM
  #74
Confirmed .. they are reflashing the stock ECU. Trans upgrade will eventually get done.
Quote: Than I'd wait on VB until you get it back. Fluid temps are the big thing when banging against the rev limiter is not the highest priority. I'm sure they can do a technosquare L-spec flash to bump the rev limiter and stuff.
Reply 0
Jul 1, 2008 | 05:18 PM
  #75
Man that thing is gonna look and be Sick!!!
How much is the Complete Setup coming out too??
Reply 0
