Black Betty Wires
on
I met up with Black Betty this past weekend and he installed the grounding kit for me (05 G35). If I remember correctly, he just took the screw out of the negative (black) cable without actually disconnecting the cable. If anything, it may have disconnected for a few seconds, but my radio presets were still there when I started my car. I cannot comment on the Navi since I don't have one. Just do this step last and you should be fine. Hope that helps.
Disconnecting the radio will remove the presets... especially if the battery is unhooked for more than a few seconds. I had the battery disconnected when I installed my paddles. Radio presets and the auto windows are needed to be set again.
Addresses in the Navi... I don't believe those got deleted.
Just saw this thread. Whether or not you lose presets depends on how long your battery is disconnected for. I don't know the magical amount if time it needs to be unhooked before you have to reset everything, but if it's only unhooked for a few minutes, everything should be OK. I've had my cable off for 15 minutes or so and didn't lose anything in memory. After disconnecting for about an hour, I had to reset radio and windows (can't remember if I had to do Navi too).
You SHOULD always disconnect the battery first before doing anything electrical as a safety precaution. I've had times when I didn't disconnect until I had to make the battery terminal connection which I do last. That way it's only disconnected fir a few moments while you add the wire(s) that connects directly to the battery
Hmm when I added my Wires or when I installed my Injen Intakes, my Batt was disconnected for more than 2 hrs Installing the Intakes, but thats with a lunch break!
and my radio Presets were still there, never had to reset them before. only had to reset my Seat memory and Auto Windows. Thats it, guess some cars are diffrent than others, LOL.
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
