Technosquare reflash+dyno
Old Feb 13, 2009 | 02:49 PM
IvoryPearl07G's Avatar
Smile Technosquare reflash+dyno
Well, i managed to make my way up to the dyno last weekend. It was a dynojet dyno that is in a controlled 73 degrees year round with no changes in humidity. both runs were done in 4th gear(speedo wrapped around lol).
I had dynoed before I got my technosquare reflash at a dissapointing 250whp in 3rd gear. almost seems like the dyno reads a little low considering how the car does against 6spd 350z's of all years. its faster lol.
anyways, this time i made 271whp. so the dyno does good in one thing, showing the gains of a modification. In this case: ~20hp gained from the technosquare reflash, and apparently its sitting around 12.0-12.6 a/f ratio. There is more power to be made in the a/f department(13.1 is ideal naturally aspirated).
Anyone know if there are any satellite shops that use technosquare programming to tune nissan/infiniti vehicles? I want a custom tune!!
Old Feb 13, 2009 | 03:14 PM
2GoRNot2G's Avatar
Very nice gains! I'll be very happy if I see similar gains from the RevUp reflash.
Looking forward to seeing the dyno chart once you post it.
Thanks for posting your results with great details (i.e. dyno type, a/f ratio, air temp, etc...). It definitely helps the rest of us make an informed decision about our next modifications. Good job!
Old Feb 13, 2009 | 03:52 PM
ANMVQ's Avatar
Nice gain with the tune, Are you an auto?? You only made 250whp with intakes and exhaust. the +20 from TechnoSquare was good..
Old Feb 13, 2009 | 07:19 PM
like i said, i was dissapointed. yea i am an auto.
but on the road(BEFORE TUNE).....
03 or 04 vq35de 350z with I/E by a 1.5-2 car lengths
05 or 06 stock revup 350z by a 1-1.5 car lengths
07+ 350z HR nismo i was side by side with him
so i am assuming it was putting out close to the same power as a nismo 350z before my tune. I wanna race another one again!
Old Feb 13, 2009 | 07:58 PM
rookie's Avatar
Nice, technically you're putting down better the Nismo since it has the weight advantage.
Technosquare can reflash based on the dynosheet if you want to take a little fuel out. Just keep in mind you're safer as is with regards to fuel qualities.
Old Feb 13, 2009 | 08:33 PM
G35Robby's Avatar
Great numbers bro.
Glad to see more people getting this tune.
It's the freaking best lol
Old Feb 14, 2009 | 01:22 AM
kool_yaar's Avatar
^ True but considering Robby pulled perfect 300whp stock with just the flash all other flash numbers are ridiculously low regardless of all the different dyno's temp stuff, 30whp is MAJOR difference between the two tunes
Old Feb 14, 2009 | 05:13 AM
G35Robby's Avatar
Well when I told Tadashi my mpg and how much my car burns, he said the richer the car the more power you will get. I guess it is true when he said it depends on the car. Depends n how the ECU adjusted to your driving, how much the car was abused, how much it has been broken in, and how rich the car runs. All these can affect your numbers.
Like i never abused my car till i hit 5,000 miles but i still didnt drive fast. Mostly speed limit. My car felt like it came out of the dealer, like the loaners lol
But my car was running rich, so that was my advantage.
I will be going back to TS once i get all my performance mods done.
emilepmartin
21
Mar 10, 2004 07:43 AM
ramo
Dec 23, 2003 05:30 PM
Chebosto
Forced Induction
Nov 20, 2003 02:05 AM
DaveO
Oct 2, 2003 01:05 PM
GurgenPB
20
Aug 23, 2003 12:37 PM
