Magnefine filter - trans oil cooler line question
Old Apr 14, 2009 | 05:13 PM
jeffawong's Avatar
Hey guys,
I wanted to install a magnefine ATF filter on my 2008 G35 sedan. I can seem to figure out which is the return (or supply) lines as the exit the radiator. It looks like it was redesigned for the gen2 cars as it does not look like the diy video configuration. (looks like gen1 cooler is on the bottom of the rad and the gen2 is on the driver side of the rad) I checked the manuals online and can't find an answer there. (the dealer was no help either)
Has anyone done this and figured this out?
Thanks for your help in advance!
Jeff
Old Apr 14, 2009 | 05:53 PM
CalsonicVQ's Avatar
On the ATF oil cooler, the inlet is passenger side and outlet is driver's side.
Old Apr 14, 2009 | 08:12 PM
jeffawong's Avatar
on my radiator - the ATF cooler inlet-outlets are located vertically on the driver side of the radiator. (not on the bottom - therefore no drv/pass tubes)
i'm looking to see if anyone knows if the upper or lower is the return.
thanks.
Old Apr 15, 2009 | 12:38 PM
rustyeleio's Avatar
Hmmm...your right, even the service manual doesn't say. The picture showing flow direction is a "schematic" style which shows the cooler running along the bottom of the radiator which is not the case.
You could get a bucket and lots of newspaper/rags. Then just detach one hose, have an assistant to start the car for a few seconds and see which way the flow is. Kind of messy but it should work. Remember to fill the transmission fluid after each attempt.
Old Apr 17, 2009 | 12:01 AM
jeffawong's Avatar
i was hoping to avoid the messy way -
am i the only one who has had the thought of putting a magnefine filter on a new car? minimizing contaminants seems like a good precaution and all around best type of maintenance since we eventually have to change out our fluid. or am i just being really ****? lol
Old Apr 17, 2009 | 01:05 PM
rustyeleio's Avatar
You will probably spark interest from this thread . But you may be the first so no one else will be able to help. The good thing is that you will be able to help the next person...
The only thing bad that I have read is that some people have complained about sluggish shifts due to suspected pressure loss after install. That being said, it was never conclusively shown to be a direct result of the new filter as there were other possible causes. And other forum members with the filter did not have the same issue. This was on some Honda forum. Same thing on another Ford forum.
Old Apr 17, 2009 | 06:41 PM
jeffawong's Avatar
Sluggish shifting? doesn't sound good. the gen2 has the same transmission as the gen1 correct? (at least the 08 G35's right?)
just to double check - anyone who had done the magnefine on G35 have any opinions/insights? (on whether they would do it again?)
Old Apr 19, 2009 | 07:57 PM
rustyeleio's Avatar
Here are some Ford poeple discussing. Looks like Ford recommends it after a rebuild but they also qualify the installation by requireing the tech to perform a flow test to make sure that pressure is not reduced below specifications. Ford even has rebadged it under their name. http://www.thedieselstop.com/archive...o=&fpart=1.htm
Another link where someone complains about the bypass valve sticking and causing high temps. He said, she said though. I don't know who is right but figured to let everyone know then you can make your own decision. http://www.thedieselstop.com/forums/...-filter-51785/
Honda has a similar inline filter OEM just to show the idea is reasonable. http://www.automotivehelper.com/topic280086.htm
Old Apr 19, 2009 | 08:31 PM
jeffawong's Avatar
thanks for the info -
i sent a message to 'bythabay' - the guy who did the diy videos for magnefine and asked him if he had any probs with the filter and he said that he has not experienced any difficulties.
still trying to track down which hose is which....
Old Apr 22, 2009 | 02:24 AM
rustyeleio's Avatar
Bump for anyone who has more info on the Magnafine trans filter???
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
