Takeda (AFE) Short Ram Intake – First Impressions
Old Aug 18, 2009 | 03:01 PM
  #106
Wes_888's Avatar
Glad to see these intakes are taking off.
They were not well received initially... lol
ultraman - you dont have to reset the ECU but its better.
Old Aug 18, 2009 | 04:55 PM
  #107
bat6wc's Avatar
why were they not received well initially?
i just have to know the diameter of the flexible hose I need to buy. My intake was delivered today!!
Old Aug 18, 2009 | 05:00 PM
  #108
ultraman1017's Avatar
I just checked should be 5/8"
Old Aug 18, 2009 | 05:03 PM
  #109
bat6wc's Avatar
thank you sir. I will be picking this up on my way home from work this evening.
Old Aug 18, 2009 | 05:22 PM
  #110
Wes_888's Avatar
because of the "outrageous" HP claims they were making and the lack of the heat shields.
Old Aug 18, 2009 | 06:25 PM
  #111
bat6wc's Avatar
just got mine. it comes with those rubber hoses already but I guess they arent flexible enough.
ill be installing it tomorrow morning.
Old Aug 18, 2009 | 08:45 PM
  #112
bat6wc's Avatar
can anyone confirm that they are in fact redesigning the heatshield to make it more complete?
Old Aug 18, 2009 | 10:08 PM
  #113
jack090's Avatar
just ordered mine too yesterday and the coupon code works too thanks!!!!!
and I have two questions hope Jack can answer
1) do I need to reset my ECU after installl?
2) what does Bully Dog do? I have a 6MT model
Sorry for the delayed responses (I've been slammed at work). I would definitely reset your ECU. It will make your re-map faster considering you have more "air" now. As far as the Bully Dog.... I've written a review and unfortunately it's very very very very very long, but to summarize I'd just read the 1st page of the Bully Dog First Impressions page. (and then possibly the last 2-3 pages).
Old Aug 18, 2009 | 10:15 PM
  #114
jack090's Avatar
I was told that they ARE working on making heat shield's from a manager at AFE. (Although there is no ETA) I was also told that originally they tested heat shields and it made no real difference when moving. The only thing that heat shield's will help is if your in high heat weather and your sitting at a stop for an extended period of time. I did my own testing and found with my K&N (which has heat shields) the temps to be roughly about +/- 4 degrees. I could never tell that heat shields made any difference when I had them.
Old Aug 19, 2009 | 11:46 AM
  #115
bat6wc's Avatar
well i just installed the Takedas. Install was pretty easy aside from cutting the tubing to make it fit. That was a pain in the ***.
The sound is amazing. Sounds great. I dont know if I feel any performance differences good or bad but it does sound good.
three problems I ran into. 1. I snapped off the center bolt to the engine cover. Half of it is on the ground, half of it is still in the engine block. 2. I have an odd high pitched sound that comes on and off every once in awhile with the engine running. Cant figure out what the noise is or where its coming from but its driving me nuts. 3. The Takeda emblems on the actual intake are peeling off. WTF!!
Im going to cruise around for a little bit but I have a feeling that these might be put up for sale very soon.
Old Aug 20, 2009 | 01:10 PM
  #116
I should be getting my package tomorrow. bat6wc, how's yours? still thinking to return it? btw, I was living in St Louis too for 12 yrs in south lemay ferry. how's weather there pretty hot?
Old Aug 20, 2009 | 01:16 PM
  #117
bat6wc's Avatar
Hey there, I ran into some issues that I talked to Takeda about and I will be returning the intake for a refund.
summer was very hot here...
Old Aug 20, 2009 | 01:18 PM
  #118
What kind of the problem you are having? please share with us
Old Aug 20, 2009 | 01:20 PM
  #119
Wes_888's Avatar
what happend?
Old Aug 20, 2009 | 01:21 PM
  #120
bat6wc's Avatar
the fitment as everyone has said is not for a G sedan. I fabricated the hoses as needed to make it fit but I wasnt happy with the fitment still. The sticker emblems on the intake peeled off after 30min of driving. All in all, Takeda and the vendor I purchased from were very helpful. Takeda is aware of both the problems and plan on creating a fix for both. They will most likely start including a hose kit like the R2C.
I just ordered the R2C yesterday actually....
