certainly ^
But then again their FMIC mounts are some really thick billet machined pieces. I wouldn't be surprised if the intercooler holds up better than the beam in a crash haha
this is good news as i am looking to do some serious power upgrades this year.
i was gearing myself towards the TT kit as the prices installed have decreased subsantially. but I have yet to own a supercharged vehicle and i think it would fit this car well
Quote:
Thank you for sharing this useful information. That keeps my knowledge up to date. Originally Posted by 2GoRNot2G
FYI... For those that are calling this a centrifugal SC... It's actually a Rotrex type unit, swhich is a centrifugal unit by definition, but it uses a completely different (and patented) type of drive system than any other centrifugal unit on the market today. HKS even tried to copy this unit and Rotrex took them to court for trying to steal their design and HKS had to cease production of their Super Chargers... Sam at GTM uses a true Rotrex unit in his kits. You can find more info on the Rotrex design here: http://www.rotrex.com/web2005/pdfs/R...ly_version.pdf.
If anyone has a comparison chart between the Rotrex supercharger, conventional centrifugal supercharger, and a turbo, it would be great
soundmike
close
- Join DateJul 2008
- LocationInside my G
iTrader Positive Feedback100
iTrader Feedback Score(9)
Liked:213 Times in 156 Posts
It probably will, but there are two things there that also bothers me:Originally Posted by Q8y_drifter
certainly ^But then again their FMIC mounts are some really thick billet machined pieces. I wouldn't be surprised if the intercooler holds up better than the beam in a crash haha
- How does it affect the crumple zone?
- How does it spread the force of impact?
It's probably moot as far as "amount of damage" is concerned. Anything strong enough to destroy the front is probably also enough to total the vehicle altogether. It's occupant safety i'm concerned about.
IMO, it will make no difference what so ever at anything over the 5MPH that the bumper is federally required to withstand. The thin walled impact beam will crush at anything higher, then the frame rail to which the impact beam was bolted to will crumple. If a large FMIC were in place instead of the impact beam, the frame rails will still be crumpling, but a bar and plate FMIC may or may no crush depending on impact force. In fact, the crumple zone may even crumple sooner than with an impact beam causing more expensive damage at low speed.Originally Posted by soundmike
It probably will, but there are two things there that also bothers me:- How does it affect the crumple zone?
An impact beam is great for minimizing damage to the cars "crumple zone" at speeds less than 5MPH ... but then again so does common sense.
soundmike
close
- Join DateJul 2008
I guess that makes sense. So you're basically saying the FMIC will actually act as a force limiter of sorts to limit the transmitted impact. Effectively lowering damages when low-impact collisions are concerned?
I've been rear-ended before, the car that hit mine had its entire front end buckled, windshield broken and part of the roof buckled as well. My rear end, well, my car
suffered relatively low visual damage, mostly to the trunk area --- still had 13k in damages after all was said and done, however.
suffered relatively low visual damage, mostly to the trunk area --- still had 13k in damages after all was said and done, however.Quote:
I wouldn't say "lowering" damages. I think it depends on the impact. Possible scenario; running into a telephone pole in the middle of the front bumper at 10MPH: impact beam will bend, the bar and plate FMIC will probably not bend as much (assuming the bracket welds hold up). The bent beam could result in the hood getting tweaked, but then again, the rigid FMIC may save the hood by distributing the force of the impact directly to the frame which may cause frame damage. Also consider that the FMIC is more expensive to replace than the impact beam and foam.Originally Posted by soundmike
In short something is gonna break and no matter what is in front and it's gonna be expensive to fix.
soundmike
close
- Join DateJul 2008
Got it. I figured something will break, it's how much force gets through to the cell i'm curious about with the front-end impact "geometry" changed.
Thanks for the input, Terry, much obliged.
It's available now! Around $5K for the "base" 500 HP kit. I'm saving my $$$.
http://www.gtmotorsports.com/product...cat=258&page=1
Ohhh wow didn't know it was ready for the G35 as well Originally Posted by 2GoRNot2G
Might jump on this but I'm torn between GTM and Stillen, but I think I'll be getting GTM since we have the tuner for them over here so it should be easier.
Quote:
No one that I know of on Driver, but there are a couple of guys over on MyG37 with this kit already.Originally Posted by suby01
so anyone on here have this??
I would go with the GTM over the Stillen. There's more upgradablility with the GTM, plus it uses a Rotrex unit instead of the Vortech unit that Stillen uses. The Rotrex supercharger is much smoother and quieter than the Vortech, not to mention more compact. Stillen's kit does come with that nice fancy looking intake manifold though. LOLOriginally Posted by Defratos
Oh, and don't forget to upgrade your tranny when you install this kit. GTM makes a really nice valve body upgrade as well as an upgraded torque converter, so your tranny can handle all those extra ponies!
That's been there for like 3 weeks now. I still don't think it's ready though. They just finished the 370Z and G37 kits and even the G37 kit is not yet shipping.Originally Posted by 2GoRNot2G
Cool thanks for that info, I was a bit unsure at first but now GTM seems the way to go
