Another GCC spec-only option
Old Oct 22, 2009 | 06:48 PM
Q8y_drifter's Avatar
I was pointed out a while ago that the G's don't have a finned diff cover (both V36 sedan and coupe). Yet I when I took a look under the car today I noticed this>
GCC Spec G's have FINNED differential covers!
Looking back at all the exhaust and sway bar threads it seems like this not available in the states.
For the US guys, here's a Nismo option which you can probably install >
http://www.thenismoshop.com/ikorb.ph...oduct_id=13265
The Nismo unit has more/larger fins than our factory part which should help dissipate heat even more It should be a direct fit assuming all V36's have the same differential case.
Old Oct 22, 2009 | 06:56 PM
kool_yaar's Avatar
Very interesting, something i never noticed, will have to check this out. You guys probably have it because the temps and conditions there are much hotter and humid.
Old Oct 22, 2009 | 07:07 PM
Definitely, but then again it means you guys have more factory options that can be purchased and installed without voiding the warranty or having fitment/performance issues.
Old Oct 22, 2009 | 09:10 PM
Defratos's Avatar
You're Despicable
Yeah mine's finned as well, never knew it wasn't stock on the US model, does it help with cooling or something?
Old Oct 23, 2009 | 05:21 AM
it acts like a heatsink to drive heat away from the diff. More surface area = more heat dissipation. Air cooled engines use this design.
prinny
Nov 22, 2015 11:07 PM
ncg35guy
Sep 24, 2015 04:53 PM
Moskvitch
Sep 14, 2015 10:15 AM
