Automatic Transmission Problems - No Manual Mode
Old May 13, 2010 | 10:16 PM
blario's Avatar
I too have this same problem. It started on a long road trip about 2 weeks ago and now it happens every time I am breaking when it is in 2nd, it goes to D. I can drive it in DS and no issues.
Old May 14, 2010 | 10:48 AM
popcornten's Avatar
Originally Posted by kendroz
part #34950M shift lock solenoid...
Better check this before, mine was dirty.
yeah they ended up changing my shifter I think... I'll take it haha
Similar, but not the exact same issue. My car just wouldn't recognize that the shifter was pushed left into DS/M so i couldn't use DS mode
Old May 14, 2010 | 07:36 PM
blario's Avatar
I think I only figured out when it is happening, knowing that the dealer would probably want to 'recreate' the problem. Once it happens, manual mode or DS are not available. I restart the car and they work - only briefly though. If I don't use manual mode at all, it will drive fine in DS.
Old May 25, 2010 | 07:00 PM
blario's Avatar
Took the car in today - it isn't the shift lock solenoid - they state it is a small micro processor in the shifter assembley.......they are replacing the whole thing next week (have to order parts) and it is covered under warranty. they said the solenoid is fine. We'll see next week.
Old Jul 9, 2010 | 02:21 PM
Byteman's Avatar
did they fix your transmission problem?
Hello,
did they fix your problem? What did they do to fix it?
I am experiencing this issue now on my 2007 G35.
This only happens when the outside temperature is 28 Celsius (82 F) or above; when the temperature goes down the transmission works correctly.
Thx.
Old Jul 9, 2010 | 06:00 PM
blario's Avatar
I forgot to update things! Dealer fixed the problem - it wasn't the solenoid, it was a micro processor in the shifter assembly - so they had to replace the whole thing. No problems since then. Weather had no bearing on it at all. It was a warranty fix as well.
Old Jul 10, 2010 | 12:26 PM
Byteman's Avatar
thanks
Mine just does it with the hot weather; other than that it works fine.
I will take mine in, luckily it's still under warranty.
Thanks for the info Blario .
Old May 1, 2016 | 06:09 PM
Loop557's Avatar
I'm a new g35 owner. 2006 sedan 82k. Could you tell me where the solenoid switch is located. Is it under the console by the shifter ? I have the same intermittent issue with mine.
Old May 1, 2016 | 07:06 PM
vqsmile's Avatar
I think you'd do better making a new thread in the correct section, rather than posting in a dormant 6 year old thread for a completely different generation of car.
Old Jul 4, 2016 | 12:29 PM
TM7's Avatar
TM7
i experience this with my 03 G35, The problem occurs when you place the shifter in manual. Then the display continues to read "D" or it goes back to "D" after a moment or two. At this point it will no longer go back into manual into the car has been restarted.
Old Jul 31, 2016 | 10:28 PM
El_Donks's Avatar
Can anyone provide info for a self install of the assembly? Checked the DIY section but didn't have any luck. I can figure out the wiring from inside of the vehicle but have no idea where/what to look for under it.
Old Aug 1, 2016 | 10:16 PM
blnewt's Avatar
Not sure what info you're wanting but here's the FSM for the 5AT, this is the 08 sedan.
Click on link then scroll down to TM.pdf for transmission FSM
http://www.nicoclub.com/FSM/G35/Sedan/2008/
Ednica87
Sep 5, 2015 02:59 AM
derres
Aug 28, 2015 03:27 PM
Srinidhi
Aug 7, 2015 03:38 PM
Cskeet
Jul 21, 2015 05:48 PM
newbdriver01
Jul 15, 2015 06:10 PM
