Kinetix Plenum seal problem...help!
Jun 25, 2010 | 03:38 PM
I just got a kinetix plenum and I am having trouble making a seal. I tried a new gasket and the car would barely start. So I tried to use RTV to make the seal and it was better but there is still a slow leak and the idle is up and down and it slowly bogs to a stall.
Any ideas on what the problem might be? I was thinking the plenum is wharfed because it didn't work with a brand new gasket and I made sure to do a good job with the RTV.
Any info would be a great help.
Thanks,
Nick
Reply 0
Jun 26, 2010 | 10:26 AM
hummm, got any pics of this plenum? and where u got it from?
Do we even have this option for the 07s? I thought it was for the 06 and before?
Reply 0
Jun 26, 2010 | 03:50 PM
Quote: I just got a kinetix plenum and I am having trouble making a seal. I tried a new gasket and the car would barely start. So I tried to use RTV to make the seal and it was better but there is still a slow leak and the idle is up and down and it slowly bogs to a stall.
Thanks,
Nick
What your problem sounds like is one of your vacuum hoses is pinched or has a hole in it. Check those before you do anything else.
Reply 0
