fluid change
Old Oct 24, 2010 | 10:00 AM
geronimomoe's Avatar
Originally Posted by slimjim2525
I am going to hit 60k this week. Would you guys do a trany drain and fill or a flush? How about a tranny shop do it rather than a nissan dealer? I hate stealers.
If it's your first time, I'd do a drain/refill. Then at the next 4 consecutive oil changes do a drain/refill.
If it's been done in the past, a flush as described in the FSM should be okay. Note I said per the FSM, not a machine flush like many dealers push..
Old Oct 24, 2010 | 10:02 AM
Originally Posted by Matchstickman60
How many quarts of transmission oil is require to fill the tranny because i am also thinking about changing the fluids over the weekend
Complete flush per FSM is about 33% more than the capacity, which is 10.875 qts.
Old Oct 31, 2010 | 12:28 AM
mifesto's Avatar
did a drain tonight and surprised so little came out... about 3.5Q hot atf. filled in 2.5Q maticS (to compensate since hot atf expands and my dip stip showed previously my tranny was abit overfilled anyways.
fluid darker red but not alarmly dark. i was going to do the transfer case also tonight but when i realized i had to rip out the underpanel, i said FORGET THAT! haha
thanksgiving weekend im going to drain/fill again.
Old Oct 31, 2010 | 12:33 AM
thescreensavers's Avatar
Mr.202?
^ I would wait for fluid to cool next time so you can get more out.
Old Nov 2, 2010 | 10:14 PM
mifesto's Avatar
whats interesting is i got about 3.5Q the first time then went out for dinner. second time opened drain nut again to see if any fluid collected again on the pan, still barely driller after about over an hour sitting in the garage.
we'll see how much comes out this coming weekend
Hawk196
Sep 22, 2015 02:51 PM
Eomfd
Aug 29, 2015 12:42 AM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
linedr89
Aug 17, 2015 05:11 PM
NemesisGee
Aug 11, 2015 07:10 PM
