cam position sensor
Old Dec 23, 2010 | 05:06 PM
freakta's Avatar
cam position sensor
so i had a light a few months back p0014. anyways bank 1 cam position failure
it went away
just came back on today p0014. so i went to infiniti. they looked through the cars history. the variable cam timing clutch had burnt out a long time ago and was replaced but no one put in the new software that was supposed to go with it. so this dealership upgraded the software for the car to see what was going on.
they are hoping thats the fix. if not they quoted me almost 1200 dollars to change the sensor. it was 625 for the part and then the rest for labor. i can see 4 hour of labor but 625 for a sensor?
so my question is. how much is the sensor really gonna cost? i searched google but everything was 50-100 bucks. is the dealer putting in extra parts? can someone make sense of this?
Old Dec 23, 2010 | 06:02 PM
soundmike's Avatar
Something's amiss. The sensor should cost no more than $200, even that's a stretch. IIRC, the sensor in this car is the same across most of the VQ line. In my old VQ that sensor set me back $125 + labor.
I suggest having it replaced soon though, it was a nightmare with my old car. The cps was erratic and would shut the car down at random times and sometimes wouldn't turn back on right away. After a dozen instances the SES finally came on. You're lucky that the light came on right away.
Old Dec 23, 2010 | 06:57 PM
freakta's Avatar
well the front two sensors are an easy fix but i think its the same ones all the way around. not sure... all my searching has just shown the de not the hr motor specs
Old Dec 23, 2010 | 07:17 PM
soundmike's Avatar
Check page 21 (onwards) of the ECS section on the FSM (ec.pdf)
http://gshack.org/?p=90
Old Dec 23, 2010 | 10:11 PM
freakta's Avatar
^^^ thanks ill check it out
Old Dec 26, 2010 | 01:59 AM
theophilus's Avatar
thats weird i had a p0011 thrown that comes on and off. as my luck would have it, every time i drive to the dealer for my appointment, it turns off. they already tried reprogramming my ecu.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
vamarris
Sep 26, 2015 12:56 PM
