Which differential fluid do you guys use?
Old Mar 27, 2011 | 12:03 PM
soundmike's Avatar
I honestly don't know for sure. But i'll tell you this, since replacing the differential oil, the G has felt "light on its feet".
Makes me wonder if the dealership actually replaced it back when it was still under warranty at the 30k mark. It looked really bad when i drained it (i have a DIY with pics in that section).
Old Mar 27, 2011 | 12:55 PM
vqsmile's Avatar
Originally Posted by kool_yaar
Yes 10mm hex socket for both on diff, and i reused the old washers cause like you said they are not crush washers and are actually hard metal washers that dont need to be replaced, when i went to pick up the MTF fluid and asked the guy said they have NEVER changed the washers on any cars cause its not required since there is no real wear or tear on it, but if you get em for cheap then changing it wont hurt.
I don't believe this is accurate. I replaced them when I did this, and they were definitely a "soft", conforming, crush-able type washer. I know they have a very humble job to do, so it's most likely passable to reuse, but I do think they ARE a crush washer.
Old Mar 27, 2011 | 04:12 PM
kool_yaar's Avatar
^ could be the case where they are technically crush washers but they are quite hard compared to oil pan and seem near impossible to crush but are worth a change even imo cause they are so cheap but my local nissan dont carry them cause they said they dont change em. but ya for everyone who is to diy should change them
Old May 9, 2011 | 09:42 PM
Nap's Avatar
Nap
I've looked everywhere for the front diff and transfer case crush washer part numbers. I'm pretty sure the rear dif crush washers are Nissan #11026-4N200.
Anyone know if the front diff and transfer case washers are the same as the rear diff?? If not anyone know the part numbers. My Infiniti dealer is 40 miles away so I want to find them online.
Mry
Mar 3, 2023 01:03 AM
bTanz
Oct 15, 2015 02:31 PM
Blakearold
Aug 19, 2015 10:20 AM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
underworld
Aug 6, 2015 01:36 PM
